Smell and overheating?
Discussion in 'The Garage' started by Wraparound, Feb 23, 2004.
  1. Wraparound
    Wraparound Registered Member
    Feb 23, 2000
    91
    Sacramento
    My girls cherokee emits an awful smell from under the hood after prolonged driving. It also threw the temp warning light on her once. The radiator doesn't look corroded and it does fine for light driving. Anyone have any ideas?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What does it smell like? I assume it's the 4.0...
  3. Wraparound
    Feb 23, 2000
    91
    Sacramento
    it was unfamiliar to me. Not like oil, coolant, or electrical.
  4. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    maybe her catalytic converter
  5. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    Was it sweet smelling at all?
  6. Wraparound
    Feb 23, 2000
    91
    Sacramento
    I've never had problems with a catalytic converter before so I might not recognize a problem there. The smell was not sweet though. Not sure how to describe it. Maybe I'll take it to big o and see if they recognize it
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    If it was the cat it would be a raw eggs smell coming out of the exhaust. So, you shouldn't smell that under the hood...this may sound kinda dumb but have ya checked around the engine to see if there's anything on it(ie rotted leaves, bugs, squirrels, toddlers etc) that could be burning???
  8. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    That's a good suggestion.
    I found a decomposing squirrel nestled next to my overflow canister once. /forums/images/graemlins/tongue.gif
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    being a cherokee.. im betting its a 4.0.. take a look and make sure the secondary electric fan is coming on with the a/c...
  10. Wraparound
    Feb 23, 2000
    91
    Sacramento
    It's nothing dead. The bodies in my basement dont smell like this. I'll check the secondary fan though...
  11. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  12. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    If it's not coming on, try wiring in a switch that you can operate manually...
  13. Wraparound
    Feb 23, 2000
    91
    Sacramento
    Part of the problem is that it uses a temp light instead of a gauge so my girlfriend isn't certain that it is overheating every time, and the times I have noticed the smell the light wasn't on and the engine didn't seem all that hot. Still gonna check the fan though
  14. Confedneck
    Nov 1, 2002
    5,236
    my 88 cherokee with a 4.0 and an auto had the problem of the fan not coming on when it should.. so i wired it to ignition hot and it ran fine until the fan gave up on the guy i sold it to..
  15. Wraparound
    Feb 23, 2000
    91
    Sacramento
    If it isn't kicking on I'll do the same.
