smell of gas? help me please help me
Discussion in 'The Garage' started by sd17sd, Aug 4, 2005.
  1. sd17sd
    sd17sd Registered Member
    Feb 3, 2005
    15
    Jackson,TN
    okay today was a great day i got new tires and some other stuff so i get home after i got off work and i took my truck down a routine trail right near my house go through it come home and go inside come back out and there is a fluid all over the ground leaking like crazy under my engine smell it and i breathe in the smell of gas oh what a smell .....so i pop the hood and i cant see any leaks up top so crawl under and all i see is gas coming down from all over well i have to move it cause were going camping so i crank it up and it stops but i turn it off and here it comes again i cant figure out where its coming from or anything has anyone ever did this please help me!!!!! :( :( :(
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    What kind of truck, year, make, model?
    Dual tanks, single tanks, where are your tank(s) located.
    Carbureted, TBI, Fuel injection?
    What kind of trail, mud, rocks, logs?
  3. sd17sd
    Feb 3, 2005
    15
    Jackson,TN
    info
    Its a 1986 K5 Blazer and its a carb ...muddy trail....um what other info do you need one tank
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Well its either a fuel line got snaged, fuel pump went bad/leaking, leaking from carb.
  5. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    Sounds like a supply line leak.
    When you start it, the fuel goes to the pump instead of the ground.
    Path of least resistance.
