Smog Help
Discussion in 'The Garage' started by onlychevy6, Feb 24, 2007.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    What can i do to get the NO (PPM) down?
    @ 15 mph Max is 1050 Ave. is 379 i measured 1229
    @ 25 mph Max is 1050 Ave. is 379 i measured 1191
    Please help. Every thing else is perfect.
  2. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Did you drive it around and make sure it was warm before you tested it? Also check your EGR valve.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Check the timing, make sure the egr works and get the cat nice and hot before you test.
  4. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    There is no Cat on this Suburban? And still has what looks like factory exhaust on it. I am going to replace the EGR soon.
    And Marc it was nice and warm before testing. Drove from San Clemente up to Lake Forest with a few stops in between.
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Kalyfournea allows +/- 4* error on timing, so set it to 5* or 6* BTDC.
  6. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I ran 2 gallons of methanol in mine to lower the NOx for my test. Lowered it by close to 30% (IIRC). I know it's not a permenant fix, but it helped me pass my emissions test.
