smog inspection
Discussion in 'The Garage' started by tunedportk5, May 9, 2005.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I finally called and made an appointment for my smog check at the refree station, and its at Wyotech in Fremont. I hope it passes. :D I got rid of of the one wire o2 sensor for a heated three wire o2 and it works perfect now.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Post up with the results. We would all like to see what happened. :thumb:
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Was it not working before the three wire O2 sensor?
  4. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    when I installed the tpi I put the o2 rite under the exhaust manifold flang and I kept get a lean reading code from the computer, so I connected a volt meter and was alway around .050 and.250 volt range, now with the heated one it's between .200 and .600 volts and no more check engine light.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You put all the crap off the TPI car, on your blazer? EGR, EVAP, ect.? Good luck.
  6. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Yea I got it all. does anyone know what the timing is. I had a picture of the label and now I can't find it to see what the timing was, does anyone know it was a 89 T/A 350 vin was 8 :confused:
  7. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Yeah no kidding, i would like to see a big fat write-up done too , ive been wondering what happened to this. :thumb:
  8. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Yea I'm finally taking it, it'll be nice to drive around without expired tags
  9. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    Good luck! I hope it passes. I had a heck of a time trying to get mine to pass last year (year late, due again soon). Keep us posted.
  10. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Well it didn't pass :( I got there around 11 and I had to wait 15 minutes until break was over and they had me pull the truck up and got my name and a little info about the truck and had me go to the waiting room for and hour about 30 minutes well they did what ever the teacher and student do and then he told me it failed, but it's not to bad all I have to do is change a pvc hose that is currently a piece of heater hose and put the timing back to 6 where it was last night before I changed it to 0, and finally the the CO reading on both the 15 and 25 mph test failed the max allowed at 15 was .62 and it measured 1.74 and at 25 max allowed is .81 and it measured 1.54 and it all might be caused by me raising the fuel pressure or maybe the timing be at hopefully. So I'm going to fix those things and make another appointment. The test was $30 dollars and the retest is going to be free and hopefully they don't stick me in a room forever watching divorce court
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    When you do go back for a retest maybe you could ask them a question for me. I have an 89 blazer and want to install a TPI set-up on it and currently from the factory there is no smog pump. I want to know if when i install a TPI from a camaro if they are going to make me install a smog pump since the camaros all had them even though i'm not changing motors but only updating the fuel induction system.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Man I'm glad I don't live in commiefornia cause of their smog testing.
  13. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I'm going to try for Friday and I'll ask them that queston, but it seems to me that there being pretty strict on the hole smog thing, max for HC allowed is only 113 at 15 mph and 93 for 25 mph, that seems to be a lot lower than what I was expecting it to be but it did pass that part.
  14. hi pinion
    Sep 25, 2003
    5,354
    DAYUM!!!!! Ive been following your deal with the tbi,,,, the whole time, im wishing you luck on the whole deal for friday. I want to see how it can be done. Sounds like a bunch of little stuff to me. Sometimes all the little stuff adds up to be one big PITA ,,good luck man, cheers :)
  15. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Dont you need to get a BAR label? You cant just get it smogged.
    Oh and Scott, whatever the year the TPI is (89-up), you have to put everything from the Camaro on your Blazer, it would be basically like an Engine Change. If the Emissions Lable says it has AIR, then you would need to put one on.
  16. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    So even though i'm not doing an engine swap but rather only the induction they will make me install an AIR system also? If that's the case then screw it, i will just install the edlebrock MPFI system that doesn't require me to install an AIR system. That would be stupid though that i could install an aftermarket induction system and not have to add AIR but if i go with a factory induction system i would have to add AIR. :confused:
  17. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    Well I hope to get to both in one shot, the label and smog
  18. scubahard
    scubahard Registered Member
    Nov 3, 2004
    47
    California
    Good Luck!
    I live in California and I had to go to the Referee about 5 times before I got my smog certificate!
  19. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah it does kind of suck. For you the Edelbrock would be better because you wouldnt need to put all the other junk on. If you think about it, you are just taking the whole induction setup, but whats left? Basically your truck is the same as the camaro, the bottom end isnt going to affect the emissions, its going to be all the PCV, AIR, EGR, EVAP, O2S, and whatever else is on the camaro that effects the emissions. Does that make sense because Im having trouble tryping whats im trying to say.
  20. RustyMule
    RustyMule Registered Member
    Dec 18, 2004
    73
    Westford, MA
    Just do what I did - LEAVE THE STATE. hehee Good luck anyway.
