Smog pass tricks?
Discussion in 'The Garage' started by DavidB, Jul 28, 2006.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Got blowby? Thanks....
  2. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    make buddys with a smog guy:D
  3. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    Move to TX where a vehicle that age doesn't have to pass emissions:wink1:
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i love texas. ive got alot of "smog" related problems and i pass with a honk of the horn and a flash of the lights. god blessed texas
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you have to remember that big truck emmissions are not as tuff as cars. through some axel gear in there, get new plugs, and run some premium before you take it to the smog shop. make sure all the emission stuff is there, if you fail once you have to get it checked by the big boys, so make sure it passes the first time.
    ARQ>
  7. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    What gears are better? Higher or lower? It's got 4.10s with tiny tires now :eek1:
    I know regs aren't as tuff...my truck doesn't require cats. Might put some on to get it to pass. I took it for a test run at a friend's place, failed. Since then I've hooked up the smog pump, new plugs, wires, snake oil in the tank and oil, octane booster, just gotta rebuild the carb and try again, right after a nice hot lap.
