smog pump.....is it needed?
Discussion in 'The Garage' started by 87'k5boggin, Jan 21, 2007.
  1. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    i have a 87' gmc jimmy with a 350,700r4,np208,10bt front and rear with 4.11's. i was wondering if all the smog crap is needed and if not what do i need to take off, also will it have more power?
  2. dyeager535
    26,980
    Consensus seems to be you don't need it. At least in regards to the ECM operation. Rarely does it seem people have a problem when removing it with vehicle operation. Not saying it can't or won't, just that common experience is it works fine without. (of course how many posts exist saying my TBI truck doesn't run quite right)
    You won't see any power from removing it. All of the smog stuff added up doesn't take enough power to be concerned with, and both EVAP and EGR contribute somewhat to mileage, so it actually may be detrimental to remove.
    If it works, leave it. If it's rotted and obviously not working right already, I'd pull it. Don't expect to ever put the pump back on though, they don't seem to handle storage very well. I can't emphasize enough that if the system is not working correctly already (leaks, etc) then you very well may see the vehicle run better...but that is NOT because you removed a properly working component.
    And if you live near somewhere that DOES have emissions testing, you will have a hard time selling it to people that live there.
  3. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    Well lets put it this way, as soon as I moved out of california I removed my smog pump, the air injectors, pluged the exhaust where the air injectors went, removed my egr, and installed a "non-smog" carb. and my Blazer has never been happier....I do still run a free flow after market cat tho...haven't gotten around to removing that. don't know if i ever will unless it causes me problems...
    But my Blazer is an 1982..there for no computer...yours being a 87 most likely has a computer so I have no ideal what effect it would have on yours....???
  4. 87'k5boggin
    Dec 9, 2006
    76
    i just pulled the belt off of the pump and cant tell to much of a difference?
  5. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i just pulled all of it off of mine. it wasnt workin so off it came!!!!
  6. 87'k5boggin
    Dec 9, 2006
    76
    im going to pull the hole pump and every thing to unclutter the engine compartment i think i have to plug up somthing, am i right if not tell me what i need to do....... also pics are nice.
    thanks,
    Caleb
