Smog Pump?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by -Jaden-, Aug 6, 2000.
  1. -Jaden-
    -Jaden- Newbie
    Jul 20, 2000
    4
    I am getting ready to replace the motor in my 84 and noticed it has a pump off some sort just under the alternator, I can only assume this is the dreaded smog pump. Dumb question but is it illegal to remove this when I reinstall the new motor?
  2. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    go for it dude!?...:)
  3. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    illegal, I do believe so. But, so is speeding. =) As long as your state doesn't inspect under the hood for emmisions equipment, who cares? So, my answer is "Smog pump, what smog pump?"
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  4. Kelboski
    306
    Mcdonough,Ga
    does that pump actually do anything, or is it just another Gov. regulation?.....i.e. catalytic convertor.....
  5. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
  6. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    jaden, let me know if you are going to rip the pump off, im moving to cali, and i might need it to pass emissions, do any of you cali guys know if its needed, the truck currently passes emissions in az without it, but i heard cali emissions are a b!*@h.
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I moved from Az to CA a while back. 86 or 87 I think. If you let me know what this thing looks like and where it is, I will go see if there is one on my k5.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MTR, 15x10 Bajas
  8. jim82
    Jun 27, 2000
    71
    Bay Area
    84, i dont know what it looks like cause i dont have it, but did you pass emissions easily when you moved? also how were they about the lift and other mods?
  9. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I put a new motor in my 85 and left the smog pump off. just be sure that you remove the emissions sticker uder the hood.
    We have the sniffer test here and the Blazer pased fine w/o it. I also have a bigger cam, Eld.intake, Holly carb.
    It's all about the tuning.
    good luck
  10. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    When we moved over here I was only 2 years old, so I have no idea what was done to the Blazer at that time. Sorry.
    Brian
  11. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I beleive Ca. does a vision test if they do not see the emmision compenet that they are looking for, you fail the test
    even if you tailpipe emmisions pass the sniffer test, which is an easiy task if the motor is detuned/tuned.
    Good luck
  12. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Yes, its illegal, yes they look for it durring the visual, and yes they will fail you if its missing, then if you fail, you have to take it to one of the recommended mech.s to fix it. Plus in the metropolitan areas, LA, San Diego, and most of the state, they put the rear up on teh dyno rollers, and measure levels at two or three speeds, with the load of the drive train on it. Yes CA emmisions are a bitch, if it conforms to the CA emmisions now, keep all of it, or else you'll have to pay a huge one time fee for a non conforming vehicle. Keep everything if you're coming to CA, i spent 15 min arguing that mine never came with a cat, which it didn't, but the book said it was optional, i knew the guy so he didn't give me a hard time, but i've had friends get screwed because the guy at the gas station was an idiot.
    RaisedK5
    "Friends don't let friends drive Fords"
  13. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    The air injector pump pumps compressed air into the exhaust to thin out the exhaust mixture to reduce back firing into the manifold and to reduce the amount of hydrocarbons and carbon monoxide in the exhaust.
  14. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
