Smog Pump
Discussion in 'The Garage' started by Hossbaby50, Feb 4, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, I need to change my fuel pump, and the smog pump is in the way. I think I will have to remove it to get the new pump in place. If I don't reinstall the smog pump with it cause any problems with the motor. Beside not being emmisions legal. (I will reinstall before the next emission test). But I am wondering if it will hurt the motor or if it is something i have to leave on to make the motor run right. Thanks
    Harley
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I've tossed mine with no ill effects.
    John
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The main problem that I've heard from people that have removed them, then tried to put them back on at inspection time, is that they tend to rust solid when not used. /forums/images/graemlins/shocked.gif So to pass inspection, they have to go buy a new pump. /forums/images/graemlins/frown.gif It's a high volume, low pressure pump, so it takes very little power to run it. Since the state will insist that you have it anyway, I'd just leave it there. Might save you some cash and aggravation in the long run. /forums/images/graemlins/cool.gif
  4. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    My '86 runs with out one, have been with out it about 2 years now problems. As for emmissions I do not have them here where I live so I dont have to worry
    LooksBack
