smog test
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mdm365, May 11, 2002.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    I went and did my smog and the tech told me the co is to high it was 6.2 and it has to be 2.5 or under.the idle is just under 800 rpm and it will not go down.I have a new 350 gm engine with a q-jet.no vacume leaks and the carb has been rebuilt,the float level has also been rechecked.give me some ideas I got to get passed !! thanks everyone mike.
  2. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    Did the smog tech give you any suggestions?
  3. mdm365
    Jul 2, 2001
    536
    mineral wells wv
    he did not say much what he said was bring the idle down but it wont,the idle adjustment is not even touching and still stays just under 800 rpm.I checked the timming,readjusted the carb and the float level also the vacume advance.
  4. dyeager535
    26,979
    How's your vac advance hooked up? Full manifold vac will bring up the initial advance, so idle/mix at idle will have to be modified. Generally, advancing timing increases engine RPM at idle.
