SMOKE AND SCENT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Aug 26, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    what is the tale-tale of white smoke from the exhaust.......also, strong exhaust odors since swapping out carbs..help, but please be gentle. my wife thinks i spend too much money on my blazer as it is.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    White smoke generally means that coolant is getting burnt in the cylinders- the prime suspect would be blown head gaskets. This can also be coupled with an increase in operating temp.
    And an "odor change" from a different carb- do you mean it's running richer? Give us a better explanation of the odor change.
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    You need a new engine ........ j/k [​IMG] ... LOL
    The white smoke could be water, or if it started after swapping the carb, and you smell gas, it could be running too rich.
    Did you get a new carb? rebuilt an old one? Install it yourself? anyone tune it?
    If the white smoke was there before, does it only happen on start up? Or do you see it while your driving around?
    Put out a little more info and we might be able to help you out some more.
    Thomas.
    -- '84 K5 Blazer --
  4. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    My K5 spits out a puff of white smoke on startup sometimes... Might be something I can look at later on in life
    79 K5 Blazer Cheyenne.... That's all I have to say about that.
  5. Can Can
    15,552
    136
    If you look close, I bet you'll find out that puff at startup is actually a light blue, not white. Every Chev I've owned has been a member of the "puff-o-blue" club.............
