smoke from one tailpipe ???
Discussion in 'The Garage' started by 4x4blazer, Oct 27, 2003.
  1. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    i put a new carb on my 350 (holley street avenger) about 7 months ago. i have been in iraq for the past 6 months and it has not been started until yesterday. i now have white smoke comming from my right exhaust pipe only(dual exhaust). it comes out constantly at idle and while driving is most visual under acceleration. oh yea, this engine has 5,000 miles on it at the most. any ideas?
    thanks,
    max
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    One possibility is a rich condition on one bank of your motor. Similar story...
  3. roadhawg
    roadhawg 1/2 ton status
    Aug 15, 2003
    495
    Oregon
    White smoke=Water/Condensation in gas
    Blue Smoke=Oil Burning
    Stuck rings are common after and engine sits, if it is definetly oil burning you might try some sort of high detergent oil treatment to free it up (Marvel mystery oil, Rislone, Ect.) I have also heard tale of pulling spark plugs and putting transmission fluid in cylinders to soak for a day or two, be sure to turn engine over a few time to pump out any tranny fluid before putting plugs back in. Transmission fluid is a very high detergent petroleum.
    I say give it hell and see if it clears up!
    Good luck! And Thank you for serving our great country!
  4. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    I had my old C10 beater do that recently. There was a pinhole leak in the head that was leaking water into the cylinder. This beast has a integrated head, I am going to part it out after I take off everything I can use on the Blazers.
    /forums/images/graemlins/truck.gif
  5. 78GMCJIMMY
    78GMCJIMMY 1/2 ton status
    Mar 29, 2003
    135
    Gresham,Oregon
    VACUUM MODULATOR! I had the same thing happen on my 78' jimmy w/ a t-350 tranny, and it smoked like a freight train!!! /forums/images/graemlins/eek.gifReplaced the vacuum modulator and problem solved!When the vacuum modulator goes REALLY bad it sucks tranny fluid into the intake port it's plugged into resulting in a ploom of white smoke! /forums/images/graemlins/eek.gif I would almost bet my truck on this one! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Just a thought, if you have auto tran's. Have you checked tran's fluid? If the Modulator is shot, the engine will pull a.t.f. out of the tran's, and burn white out the tailpipe, usually cylinder's, 7 and 8 plug's will be sooty/wet.
  7. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    ok, shortly before i put the new carb on, i found that my #8 plug had fouled and there was alot of sludge build up on it. so this modulater theory seems to fit so far. now if someone could just tell me where the modulator is and what it looks like.....
    thanks again.
  8. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    never mind, i found it on the side of the tranny. i'll try replacing it i recon. thanks for the advice.
  9. 78GMCJIMMY
    Mar 29, 2003
    135
    Gresham,Oregon
    thanks again.
    [/ QUOTE ] #8 plug fouled=bad vacuum modulator!!!!GOOD LUCK! A quick and easy fix!! /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  10. 4x4blazer
    Jun 14, 2000
    278
    Louisiana
    ok. the modulator didnt fix it so i pulled the #8 plug and put my compression checker on it. guess what...no compression. not even a little. and the plug was oil soaked. so i am guessing that i burned a hole in the piston. i am thinking that if it was just the rings that there would be a little bit of compression. well, i guess this is what happens when someone who doesent know what they are douing builds an engine by themselves. this has to be some sort of record.....burning a hole in a piston in 5000 miles or less....well, i better get to workin on it.
    thanks for yalls help.
