Smoke while jump starting
Discussion in 'The Garage' started by mud390, Jan 14, 2004.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I tried to start my 84 K5 about 10 minutes ago after it had been sitting for about 4 months. It normal fires right up without effort, but I expected more trouble this time. I turned the key and nothing. No clicking or even trying to start. I hooked up the jumper cables to my 01 GMC and hooked the ground to chassis ground on the 84 and I touched the positive to the + on the battery and got sparks. No biggy. Adjusted the cables on the 01 and tried again to get a nice little plume of smoke from around the starter (I think) with that wonderful burnt wire smell. Any ideas of what happened here. Oh, still no start. Any and all help would be great! Thanks!
    Kris
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Are you positive your ground to the chassis wasn't touching anything else?
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you sure that your battery cables aren't super crappy?
  4. mud390
    Oct 31, 2002
    1,210
    My negative jumper cable was attached to the alternator braket. My battery cable are in good shape. No fraying or cracking at all.
    Kris
  5. clubba68
    Dec 6, 2002
    1,511
    Is the alternator bracket adequate grounding? /forums/images/graemlins/thinking.gif
  6. mud390
    Oct 31, 2002
    1,210
    I've always used that and never had a problem in the past. That is a good question though? It should be grouned well enough.
    Kris
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Thats where my ground wire is...from the battery to the altenator bracket. Is this a bad spot for grounding?
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I think the spot is fine. There is quite a bit of metal etc.
  9. clubba68
    Dec 6, 2002
    1,511
    Apparently not. I was just curious.
  10. mud390
    Oct 31, 2002
    1,210
    Any thoughts on what I fried when I saw the smoke? I was looking at the wiring diagram and I was thinking maybe the fuseable link. /forums/images/graemlins/confused.gif Maybe ??????
    Kris
  11. mud390
    Oct 31, 2002
    1,210
    help...
    Kris
  12. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    mabey crappy wireing at your starter or something chrossing the posts?????
  13. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    I would get up under it and check all the wires on your starter, I had one fray one time and arc out, fried my starter I would start there
    Just my 2 cents
  14. mud390
    Oct 31, 2002
    1,210
    Thanks for all the input everyone! I guess I get to be an electrician tomorrow and figure out what is going on. Should prove interesting. I'll let you know what I find and try to take some pics if anything was damaged. Thanks again!
    Kris
  15. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like fusible link, or arcing between starter posts..
    for future reference, and for your safety.. hook up the positives first, then the grounds, should reduce the chance of arcing..
