Smokey Engine
Discussion in 'The Garage' started by bigred85, Oct 11, 2004.
  1. bigred85
    bigred85 Registered Member
    Jul 12, 2004
    61
    Dallas, TX
    I just started up my truck for the first time in a couple of months. After letting her run a few minutes, I noticed quite a bit of smoke coming from my exhaust manifolds. What could cause this?? Are my valve covers leaking right onto my exhaust manifolds? Is it better to use the fiber gaskets or the RTV stuff??
    What color RTV should I get??
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I use the felpro rubber gasket with no RTV and have had great luck with them compared to the cork gasket.
  3. dyeager535
    26,975
    What color smoke? White could be very possible, due to condensation in the exhaust burning off.
  4. bigred85
    Jul 12, 2004
    61
    Dallas, TX
    It is more of a light grey than it is white. I can understand blowing smoke out of the tailpipe, but this is coming from under the hood.
    /forums/images/graemlins/confused.gif
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Are you sure there wasn't something living in there????
  6. bigred85
    Jul 12, 2004
    61
    Dallas, TX
    With my luck, I bet there was!!!
    But seriously, the smoke looks like it is coming from the rear of the exhaust manifold, near where it goes into the pipe. She does not sound any different from the last time I had her fired up.
    I am totally CONFUSED!!!!!
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    my buddy's Blazer sat for a while. When he finally started it up he heard the damnest noise. Turns out a cat set up house in the fan shroud.......what a mess /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Had that happen to mine also (not the cat) and my valve cover gasket was seeping on the back and dripping onto the header. Almost looked like it was on fire with so much smoke rolling out of there, but the leak was hard to find.
  9. bigred85
    Jul 12, 2004
    61
    Dallas, TX
    So should I just replace the gasket and hope for the best?
    Do I need to clean all of the oil off of the exhaust manifold, or just let it burn off??
    PS hey fireman, where exactly is "LHC,AZ"? I visit Family in the Phoenix area every year or so.
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    could be coming from your oil pressure sending unit too. Though kind of unlikely, mine was leaking there, dripping down my oil filter and on my header. Just let the oil burn off, wont hurt anything as long as they are not coated with oil. Change the gaskets on the valve cover to some felpro rubber jobbers, cheap and easy to do. Look around your manifold as much as possible, small block chevys are noctorious for leaking right where the top of the block and the intake meet. Good luck finding leaks, even my newer stroker tends to leak a little bit of oil here and there. I dont think a small block is running right if it aint leakin a lil oil. /forums/images/graemlins/thumb.gif
  11. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Hey then my Blazer must be runnin like a top fueler!!!! /forums/images/graemlins/screwy.gif
  12. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    I would start by degreasing the motor, just to get all the oil & dirt off. Puchase the felpro rubber gaskets, I bought mine @ Napa. Clean the surface of the head and valve covers. Also other probabilities are the oil pressure sending unit as stated above and the back of the intake manifold also but I would start with the sending unit and the valve covers...........LHC is Lake Havasu City. About 50 min west of Kingman or 2 1/2 hours west of Phoenix.
