Smokin' 73 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Feb 9, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    Smokin\' 73 K5
    I just bought a 73 k5. I was told the 350 was rebuilt recently(or a newer motor swapped in, it has HEI). It has a small smoking problem upon startup and when I hammer the throttle. It runs nice and smooth from what I can tell. I also have a real bad exhaust smell, how can I tell if it is running rich or lean. The valve covers have like 2 or 3 extra breather holes open(what's that?). Thanks
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Smokin\' 73 K5
    what color smoke? white? black? blue??
  3. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    Re: Smokin\' 73 K5
    mostly white, sometimes black but only for a second or two.
  4. Confedneck
    Nov 1, 2002
    5,236
    Re: Smokin\' 73 K5
    well black would be fuel.. as in running rich and not burning it all off...
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Re: Smokin\' 73 K5
    White smoke sometimes means that steam is getting in the exhaust. Your head gasket may be leaking and needs replacing or maybe your head bolts just need tightening...or it could be a catalyst burning off fuel residue in which case your AIR injection is FUBAR but I'm pretty sure you don't have AIR on your 73....
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Re: Smokin\' 73 K5
    With all the engines i have had, i still have never seen "blue" smoke when burning oil. My last car, "88 Iroc Camaro with 165k miles" used oil and smoked at start-up, and now my current vehicle, the '89 Burb with 206k miles definately uses oil, smokes at start-up, and slightly after idling for a few minutes then the throttle is hit, it will smoke for a few seconds, but to me, this appears to be "white smoke. I do know that this is caused primarily due to bad/wore out valve seals which is common in the Chevy small blocks. Now i have had a head gasket or two go bad and leak down into the cylinders, and you can definately smell coolant vapors coming from the pipes. Now don't get mad at me, i am just saying,,,I don't see the blue???
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: Smokin\' 73 K5
    It is a blueish/grayish smoke that you should see if it is burning oil. It isn't electric blue smoke but it does have a slight blue tint to it.
  8. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Smokin\' 73 K5
    Is it white smoke or just vapor?
    I notice you live in a colder climate, could this be the issue?
    Pull and read the plugs for signs....
