smokin 84 6.2 diesel
Discussion in '1982-Present GM Diesel' started by crewchief264, Jul 8, 2002.
  1. crewchief264
    crewchief264 Registered Member
    Sep 24, 2001
    11
    indiana
    my kid brothers military blazer is puffin white smoke out the left exhuast and is accompanied by sever power loss. it'll idle all right and then when you put it in gear and try and take off it has no power you can only go like 15 mph if that fast any body gaot any hints? all the filters are changed and it ran real good before.
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    White smoke= water or coolant in the combustion chamber. probally a blown head gasket or worse.
  3. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Could be an injector too. Try testing or replacing all the injectors before you do a head gasket.
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    The butterfly valve in the left exhaust manifold may be stuck, I think its called the EPR valve or something. Anyway, youll have to take the pipe off the manifold to see for sure unless somebody knows a way to see if its stuck with the pipe still on. This would explain the low power cause of a massive exhaust restriction, and the white smoke is unburnt fuel, possbibly because that side is not getting enough air to properly burn the fuel due to the cylinders staying filled with exhaust. If its not stuck then I would look at fuel timing or a blown head gasket, possibly other things.
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    The way to tell if it's worse then a head gasket is if you pull the dipstick, not filler neck! and watch for belching white smoke! If so, probable cracked block!! /forums/images/icons/crazy.gif /forums/images/icons/blush.gif IF no smoke coming from bottom of engine, blown head gasket would be my next explination, but always try the esier solutions first!
