Smokin' Blazer!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin'Grrl, Aug 13, 2000.
  1. Blazin'Grrl
    Blazin'Grrl Registered Member
    Mar 24, 2000
    54
    Indiana
    Smokin\' Blazer!
    OK, my Blazer's smokin.' It's steam-like smoke, not black or anything,and looks to be coming from the block...not from the radiator and anywhere around that area....It does it even if I drive a short distance. The Temperature is fine, staying below 200.....any ideas? Should I be worried??
    <font color=purple>Sarah</font color=purple>
    <font color=purple>[​IMG]'83 K-5 Silverado Blazer[​IMG]</font color=purple>
  2. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Re: Smokin\' Blazer!
    If it was mine, I'd be concerned. It is certainly worth a look with a flashlight. It might be just a softplug gone bad. Not always easy to get to, but should be fixed. You know it's not going to get any better, only worse.
    John
    So Much to do, So LITTLE cash.
  3. Grim-Reaper
    7,385
    Atlanta
    Yeah check it out and find where it's comming from.
    Might be somthing as simple as the heater hose leaking where it meets the intake or a leaking freeze plug. May be something more serious like a failing head gasket. Check the oil and make sure it's not getting a chocolate milk look to it. That would indicate water getting in the oil and that will toast the engine in a hurry. Also check the coolant and make sure it hasn't gone brown or black.
    Make sure to keep the radiator topped up and carry water with you if your going to keep driving it.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with Grim about the heater hose thing.........A few years back, I had a hose split under my hose clamp- a really sneaky break! I lost just enough coolant once the engine warmed up to cause steam, but there was no sign of liquid anywhere! The big tip-off was the antifreeze smell it gave off. It took some checking, but I ended up finding the culprit by running the motor with the hood up and watching closely while everything warmed up.
