smokin like a bob marley concert!!!!!!
Discussion in 'The Garage' started by wild-will, Sep 8, 2003.
  1. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    Hey i just took my truck out for the afternoon romp on the ricers and more smoke came out of the engine then at a bob marley concert it came out of nowhere do you guys got any quick suggestions
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Start with valve seals. Cheap, costs mostly time. You can check the valve guides for excessive wear while you're in there. How do your plugs look?
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    What color of smoke? White? Blue?
    Auto trans?
  4. wild-will
    Aug 21, 2003
    185
    Oak town WA
    I'd say white or grey
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If it's white it means coolant. Where exactly did the smoke come from? The exhaust or the engine bay?
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    White or grey, Auto tran's? If an auto check it's oil. Vacuum Modulator's go bad[the diaphram break's] and the engine vacuum will pull tran's fluid, and burn it.
  7. wild-will
    Aug 21, 2003
    185
    Oak town WA
    it was dumping out the muffler (there's a hole in one of em) and when i threw open the hood it looked like it was coming from the headers but i think that was just the smoke under the truck routing up through the hood
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    You were actually lucky enough to see a Bob Marley concert?
    man I wish I could have been that lucky!!
    Good Luck.....
