Smoking out of valve cover breather
Discussion in 'The Garage' started by 85mudblazin, Mar 25, 2006.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    So I got the truck running and all. As it is warming it up starts smoking out of the valve cover breather holes. Whats the cause of this??
    -Chris
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    is it actually smoke or is it just water vapor(from condensation inside the engine)?
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I guess it could be just steam. I guess I just need to run it long enough and see if it goes away.
    I cant think of anything that would actually be burning in there.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Blowby as well. First it is the moisture boiling out of the oil and after it reaches a good temp, it's blowby.
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Hows your compression? Got a blowby problem perhaps?
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    PVC system hooked up and working?
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Well I ditched the PVC valve for just a regular breather so this could be my problem. Thing is a buddy of mine runs the same and he doesnt have this problem.
    Guess ill try putting it back on and see if this stops.
  8. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    a reminder - breather on driver's side pcv on passenger's side.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Every stock K5 that I have seen has had it on the driver side and a breather on the passenger side.
    But on a side note installed the PVC poof no more smoke:D
  10. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    why is this?
  11. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Mine is the opposite of that. Of course my motor isn't running correctly. But the last motor which did run ok, had the same setup.
  12. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    most ofe the times ive seen it, its been pvc on the pass side and vent on drivers. anyone know why theres a differance with some setups? and is one right?
  13. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    the way I remember seeing it explained - was due to the direction of engine rotation. which seems to make sense.
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    My truck has the breather hose run into the air intake on the passenger side. the Valve covers on both of the 350's I've had were set up with breather on the passenger, and PCV on the driver side. I'm 99% sure that's the way these two came from the factory, but I may be wrong
  15. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    having a PVC important...
    The PCV valve should never be eliminated..it will allow pressure to build up in the crankcase,cause oil leaks,even blow seals ..and it helps a great deal to eliminate water vapor in the crankcase and keeps blowby past the rings to a minimum..it also affects your carb's air/fuel mixture,its designed to run a bit rich,to make up for the vacuum "leak" the PCV creates..blocking it off will richen the mixture considerably,could lead to oil dilution..
    All the chevy V8's I had, the PCV was on the drivers side valve cover,AFAIK...I have seen many "re-located" and swapped sides due to custom valve covers,etc,with no bad effects..older 283's had a PCV valve that threaded directly into the base of the carb,where the power brake hose is usually located..
    I'm not sure if it really matters WHERE the PCV valve and breather is located,as long as you have BOTH,and they are functional,since other GM engines have them in the intake valley pan,etc..one qiuck way to blow a motor up is to not have a breather,but retain the PCV valve..it will suck the oil out of the crankcase slowly but surely,and lead to seizure..seen it happen many times on motors with "bling" aftermarket valve covers with no provision for a stock breather..some have no provision for the PCV valve,or an oil filler cap either!..:screwy:..
  16. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I've got a breather cap on the passenger side (rear) and a PCV valve and hose on the driver's side (front, because it's easier to check and change up there!).
