Smoking pipe!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Moose, Jun 17, 2005.
  1. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Ok guys i did a search and can't seem to find why. Started the wifes 89 burb and I noticed it was smoking a little ( a rich smell). Drove it and noticed it just keep smoking. Stopped at a light shut it off and restarted it no more smoke. Got any ideas? :eek1:
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Leaking valve guide seals. Had it happen to one of my other chevy's.
  3. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    What color was the smoke ? Blue= oil, black= rich fuel mix
  4. Moose
    1,062
    Glendale, Arizona
    black.
  5. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    You can tell if it is running rich by the color of your plugs. Pull a couple of easy ones and check them out.
    Oh and as soon as I go back to work (June 24th) I will be picking up your T-shirt! :D
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine blows a puff of white smoke every time I start it.
  7. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    mine too. does it for about a minute then no more smoke.
  8. blazer1978
    blazer1978 Registered Member
    Jul 8, 2005
    7
    Montreal, Quebec
    I'm running true duals and getting some smoke out the RT bank.
    Not much but wont go away. Can't tune the carb anymore than what it is for air/fuel ratio. Guess I need a carb rebuild...
    As for white smoke that goes away...it's moisture in the engine that burns away. Common on most cars until the engine warms up and the choke comes off. :crazy:
