smoking wires
Discussion in 'The Garage' started by diaedy, Aug 15, 2005.
  1. diaedy
    diaedy Registered Member
    Jun 14, 2005
    19
    Ct
    Yesterday my son came home and went to start his truck when smoke started coming out a/c vent. What happed was that where he put his tack wire through the firewall it shorted out and in the process burnt through the water temp guage wire that is all coiled around the heat wire. So bad it melted the tack and water wire together. Now that he replaced them the truck WILL NOT START. Not even fire. There is 12 volts going in to dist from the purple wire but nothing coming out to plugs. HELP
    The truck is 1985 350 with the dist an coil all together.
    Thanks. Not to keen on how this dist works.
    diaedy :mad:
  2. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    Im going to take a guess and say you probably fried the coil when the wires shorted out.
    you might have also blown an inline fuse (can`t think of correct name, fusable link, I think)
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    If It Were A Fuse You Wouldn't Have Power To The Coil, I Agree That You Either Killed The Coil Or The Module. I Would Take The Module Out Of The Distributer And Take It To The Nearest Parts Store With A Tester And Have It Tested Since It Is The Most Sensitive Part Of The Two. I Would Also Do An Ohms Test On The Coil To Check It. The Haynes/chilton Manuals Both Tell How To Do The Coil Test.
  4. diaedy
    Jun 14, 2005
    19
    Ct
    blazerguy
    Not to sound really stupid butis there a quick way to check the ciol?
    many thanks
  5. diaedy
    Jun 14, 2005
    19
    Ct
    Jebsr
    Yes indeed. Think I will do that tonight. i do have an ohm mneter heree at the house an was not sure abot the moduel. Maybe hopefull thinking that it would not be that. thanks
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Auto Zone and Advance auto parts have ignition module testers and they'll do it for free.
  7. diaedy
    Jun 14, 2005
    19
    Ct
    thanks
    It was the coil . Replaced both at seperate times, both module an then coil, and that did the trick. I really appreciate the help as my knowledge is limited.
    diaedy
