snag installing locker, *UPDATE* almost done
Discussion in 'The Garage' started by BranndonC, Dec 13, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok i'm stuck here... read step 23 and 24 then if you have any suggestions let me know
    Regular BELOW
    Side Ways BELOW it shouldnt be like this..
    Tech support is closed, if anyone here can help me, id appreciate it /forums/images/graemlins/thumb.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Re: snag installing locker, re: gap in carrier
    Sorry I can't help, but if you had installed a detroit you just open the carrier and remove everything and then install the locker and bolt it back togother again.
  3. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    There are 2 steel rings (one on each side gear) that look similar to the gage ring. Did those come out with the side gears or are they still in there holding out the 2 sections.
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    came out, but i tested it both ways, and it didnt help. But what i did do was flip over the whole carrier so the longer part was on bottom instead of top like in this picture
    http://www.branndonandbrianne.com/branndon/blazer/3.JPG
    and it seems to fit fine now, so i think that was the problem, because in there picture also the lobger part is on bottom. Anyway. Thanks
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Re: snag installing locker, *UPDATE* and new question
    oh how in the hell does this little retainer pin thing come out of the D60 ? (fyi just for those that dont know, this is a different axle than the above pic)
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i think thats supposed to be able to have an allen wrench inserted but it doesnt look like it can
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thats kinda what i'm thinking, its totally hallow, i can stick an allen long ways and come out the other end.... wierd /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  8. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    If it's hollow all the way through, then it's probably a roll pin, and you should be able do drive it out with a punch. At least, that's my best guess anyway /forums/images/graemlins/grin.gif
    Roll pins on the 205 are just like that. You can run something all the way through to the other side b/c they're hollow.
    BIGJ
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so i need to go to sears and buy the special punch? then re use the old pin or get a new one from home home depot or kragen or something right. And is it at all possible to punch it out while the ring gear is installed. someone one told me no, but i dont wanna remove the ring gear if i dont have to. Thanks
    Branndon
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am pretty sure you cannot drive it through to the other side. I have used an ez-out and lightly tapped it into the roll pin then carefully twist it while pulling outward. Hold the ez-out with a visegrip so you can pull outward while turning it counter clockwise.
  11. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    just get a long punch and drive that roll pin out, you can re-use it, but a new one is always a good idea.. /forums/images/graemlins/thumb.gif
  12. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    we couldn't for the love of god get that roll pin out on mine--we ended up getting a BFH and pounding the center pin till it came out the other sied and went to Lowes to buy another pin. if it looks like the center pin will clear the ring gear you wont have to take the ring gear off.
  13. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i have no insight other than blut nails work really well for driveing out roll pins. like grind the point off.
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Branndon, that is a roll pin like others said. You do not need a fancy punch. Just find any punch that is slightly smaller than the diameter of the hole in which the roll pin slides thru. Don't use a BFH as all you need is just any regular household hammer.
    Just take your time and hold the punch squarely on the roll pin head and tap it. If it don't move, tap harder. Just keep at it and it will break loose.
    Patience here, just take your time. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is a roll pin, definitely. I believe that all Dana axles have roll pins instead of bolts.
  16. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks everyone, got the roll pin out, locker is in and in process of bolting everything back up. Should be finished tomorrow. Thanks again. CK5 ROCKS!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  17. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Hows the rear axle coming?
  18. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    great got it in and bolting it back up tomorrow, just cleaning off old RTV and odds and ends /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  19. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I'm curious if ya had to take the ring gear off the carrier to get the cross pin to come off? Be nice to know for when I do the Detriot in my 60.... /forums/images/graemlins/pimp1.gif
  20. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Err...wait...The Detriot for the 60 replaces the whole carrier right? Hmm, duh. Have to take the ring gear off anyways to put on the Detriot. lol Duh.. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/thumb.gif
