Snap ring failure, tossed a cap
Discussion in 'The Garage' started by 1985_K5_Silverado, Mar 6, 2006.
  1. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    motoring along at a steady 35, THUNK!!! on the bed floor; THUMPTHUMPTHUMP immediately thereafter. I first thought blowout, but it still still steered and rolled fine. Pulled over and shut down. Took a look underneath and saw that the rear u-joint had tossed a cap and started to shake like mad. No big deal, easy fix. It could have been more eventful, but I wasn't going very fast when the snap ring apparently failed.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Did it fail, or did you forget it?? I forgot one once, spit the dshaft out at 70 mph.
  3. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Nope, they were on there when the nearby front u-joint was replaced a couple of months ago. I should have done them both at that time, even though the rear looked and operated all right, just because even a top-quality u-joint is a relatively cheap part and I had no idea of how old either u-joint was. You live and learn.
  4. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    when i drop a shaft for a joint it gets both or all 3 if its a 2 peice shaft. :rolleyes: at least it didnt drop and take out other parts.
