Snap ring help
Discussion in 'The Garage' started by sandawgk5, Jun 4, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I need to know the size of the size of the snap ring that goes on the stub shaft for a dana 60 that is used to pull the seal tight against the knuckle. It is the one that goes on the stub shaft inside the locking hub.
    Ira
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What measurement do you need? I have my D60 apart right now and can take any measurement you need.
    BTW. I am transferring to SD in about 6 months or so. We will have too meet up then.
  3. sandawgk5
    Oct 28, 2003
    6,881
    I am looking for the inside diameter and possibly thickness of a 30 spline stub snap ring. I need to buy some as I dont have any and I am trying to reassemble today. I know they are not required but they are there for a reason and I feel like I should put them on. For sure when you head this way let me know. I will be transferring to Norfolk in June. I will be going to the Teddy Roosevelt.
  4. readymix
    May 30, 2004
    6,706
    26
    OK. Give me a few minutes and i will get back to you with the measurements.
  5. readymix
    May 30, 2004
    6,706
    26
    I know it is a big pic. I kept it like that for ease of reading the text. The direction of the lines indicate where the measurements were taken. If you need any other measurements just ask.
    I also put the ID line in the wrong place for the Chevy D60 measurements. The lower line should be ID not OD
  6. sandawgk5
    Oct 28, 2003
    6,881
    Thanks for the info I hope I can find them at the parts house.
