snap ring removal in the14blt hub.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Sep 7, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I’m replacing all the seals in the 14blt and I can’t seem to get the snap ring out that holds in the outer bearing in the hub. I tried to use some s/r pliers but the tips stared to bend. Do I just need a big pair of s/r pliers or what.
    Thanks,
    Charles.
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I used two pair of pliers and a fairly large flat head scewdriver. Takes a bit at first. Just keep at it and they should come out.
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I went to harbor freight and bought a pair of 16" needle nose pliers and they worked perfect. No problems at all, the snap rings came out on the 1st try and went back in just as easy.
  4. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I had the same problem, but I ended up breaking one. I finally got it out by using a punch to move the race slightly away from the snap ring. The snap ring came out easily after that.
