snaped my first rear end
Discussion in 'The Garage' started by 91k5NC, Oct 21, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    well just driving down the road friday went across one of those big speed bumpes and about ten feet after that i herd a load crack and it jerked the hole truck so i thought i could lemp it home just thought it was a u-joint but it done it again so pulled over and took the drive shaft out and went home. bought another ujoint and put it end and still done it, pap said congulations son you 've blown your first rear end. so we took the cap off the rear there was a piece of gear laying there and couldn't get the pin out to take the axels off then we seen i busted the case. sorry so long but just had to tell yal!! going to get another rear end and see if we can fix. /forums/images/graemlins/k5.gif /forums/images/graemlins/grin.gif it. /forums/images/graemlins/k5.gif /forums/images/graemlins/grin.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Naw! Can't be! Everyone knows that a 10-bolt rear won't break if you're running tires that are 35 inches or less. /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
    Welcome to the club! /forums/images/graemlins/cool.gif I've blown apart 3 12-bolts and 2 10-bolts in 3 different trucks. /forums/images/graemlins/shocked.gif The last one was the "little" 10-bolt in my S-Jimmy. 4.3 liters and 30 inch tires. Still managed to break the pinion gear! /forums/images/graemlins/mad.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Sounds like it's time for a 14 Bolt FF. If you're going to put a different rear axle in it, might aswell get the good one.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i agree do it right the first time just put a 14ff in /forums/images/graemlins/smile.gif
  5. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    That happend to my 10-bolt in my burby /forums/images/graemlins/crazy.gif, I split the carrier down one side and broke the pin in half. Now I got a 14-FF /forums/images/graemlins/grin.gif and I never half to worry about that breaking. /forums/images/graemlins/burb.gif
