Snorkel kit for Blazers?
Discussion in 'The Garage' started by grizzlyoffroad, Apr 2, 2006.
  1. grizzlyoffroad
    grizzlyoffroad 1/2 ton status
    Mar 31, 2006
    100
    Soldotna, Alaska
    Does anyone out there make a snorkel kit for blazers? I know I could fab one out of pvc or somthing, but it sure would be nice to find a custom built one that looked as good as it worked. I see them for Jeeps and Landcruisers all the time, but not for Balzers. Would it be best to just route the intake into the cab if you are going to be in a lot of water or mud? Whats best to use for the air cleaner encloseure? Custom or are they out there somewhere?
  2. Muddytazz
    Muddytazz 1 ton status Premium Member
    Jun 30, 2002
    20,093
    Salem, Or.
    Landcruiser FJ80, almost a perfect fit. Otherwise, NO ONE makes them for our years of K5's/Burb's/Trucks
  3. cbbr
    Jul 17, 2004
    14,688
    High velocity, Low altitude
    I think that maybe one of us should as this question gets asked about once a week.
  4. Muddytazz
    Jun 30, 2002
    20,093
    Salem, Or.
    :haha::haha:
  5. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    860
    Louisville, KY
    Would a snorkel kit inhibit air intake flow for a carbed engine? I was thinking of fabbing one up, but read somewhere that airflow would be restricted too much. ??
  6. Muddytazz
    Jun 30, 2002
    20,093
    Salem, Or.
    Check out Rootbreakers rig, he's running one ona carb'ed motor with no issues
  7. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
  8. RootBreaker
    RootBreaker 1/2 ton status Premium Member
    Nov 29, 2001
    4,746
    Williamstown, NJ USA
    restriction... no... in the way.. maybe.. just put a stick through it from a pine tree.. busted out the grate in front of it... but all in all... works ok.. mine isnt water proof... yet....
    it is mainly more for that.... ya go in and got 300 foot to go.. do you stop or floor it????? :haha:
    didnt get a great pic.. I was over the bumper deep.. this is coming out of it...
    fj80 snorkel.... $300 to my door from 4x4connection.com plus $20 from home depot...... not cheap but hell if you want anything right ya cant spend $10!!!!
  9. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,230
    FrankFort IL
    hey i like the snorkel but is there any way to pull it into the cab a little more like with a hose clamp or something seems to stick out ehough to want to get cought on stuff
  10. RootBreaker
    Nov 29, 2001
    4,746
    of course.. if you dont have ac.. just cut a hole on the firewall and into the cab.... or come up from the floor.. I dont mind where mine is... personally I should have finished it.. the snorkel pushes up to my cab almost.. I just havent finished it as it looks far away from the cab. I will get that done soon.... Also I could cut the snorkel down and get the intake lower as I dont think I will ever need to use the snorkel up that high.. unless I have scuba gear on!!!! :haha:
  11. ProJunkRacing
    Jun 20, 2005
    1,230
    FrankFort IL
    yeah i like the arb one but i dunnno if i like it enoght to spend 320 on it that could buy my truck something cool
  12. RootBreaker
    Nov 29, 2001
    4,746
    well my wife said do it right or dont do it at all... hence the $$ spent on the arb....
    i even did the az-kickin.com rear disc conversion.. using d44 calipers... when she found out I didnt have an ebrake.... she made me (:bow: ) buy caddy calipers
    ya can go anyway you wish.... some things you can cheap on and some ya dont.... depends on what ya want....:wink1:
  13. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    Grizzly Likey
    Holy cow, that is a nice Blaze. If i am not mistaken, that is the same Blazer that was in the Top Truck Chalenge a few years back. In all my hopes and dreams, that is what I want my blazer to turn out like. Maybe one of these days...after about $50K. Thanks for the pic.
    PS. Thanks guys for the ideas, sounds like the FJ80 type is the way to go
  14. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,909
    5
    Oregon
    is there a reason you chose to run the intake as "forward"? seems it would be better to face it "backward" so that you don't end up slinging mud/water down the snorkle.
  15. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    As you drive down the road you get more air?
  16. ProJunkRacing
    Jun 20, 2005
    1,230
    FrankFort IL
  17. colbystephens
    Feb 24, 2005
    10,909
    5
    Oregon
    could it have a swivel head to turn it around for off-road situations?
  18. RootBreaker
    Nov 29, 2001
    4,746
    it is held on by a hose clamp.... so yes you can turn it around.. I havent got any mud in it ..... YET!!!!!!
  19. shoudabinacowboy
    shoudabinacowboy Registered Member
    Jul 26, 2005
    82
    Gold Bar, WA
    Hey Rootbreaker how do you plan on moving it closer to the cab? A little heat gun action?
  20. RootBreaker
    Nov 29, 2001
    4,746
    no there are no bolts up there so it has play in it.. when I go down the road at 50mph.. it vibrates back and forth... about 2" play.. maybe ill get that squared away this weekend....
