Snorkel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SlyDog, Dec 12, 2000.
  1. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Im just wonderin if anyone here has or ever has had an exterior snorkel on their blazer? I've seen them on some toys and hummers but i just wanna know if you've had one? Thx
    [​IMG] SlyDog [​IMG]
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You can make one work for an FJ60(that is that one I believe) from ARB.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Yeah ive heard about that But "when" i get my blazer i wanna make a custom one for 15$ instead of pay 200-300$ im lookin for some plans
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ooppss.. Sorry, I thought that is what you meant. I think TXmudder or Thunder made their own snorkel, hoepfull they will reply and help! :)
    Mike [​IMG]
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    I saw a custom one on a big old Ford that used Semi-truck radiator hose for plumbing. It is 4" in diameter. The toughest part of a snorkel design, IMO, is figuring out which part of your truck to cut to run the snorkel up.
    "If it aint broke...Make it work better!"
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Heck Blue85, that's easy! Cut the fender that already has the most/biggest dents. [​IMG]
    Actually, I think you'd want to do it on the right side. It would block a larger part of your field of view mounted on the left (unless you've got a right hand drive K5!) [​IMG]
    http://ThunderTruck.ColoradoK5.com
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  8. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Thanks guys for the help i was gonna put it on the left but your right about blockin vision but it takes more tubing! lol how come more people dont have snorkles if it saves your engine ( i know some guys never see water so dont say that but the majority due i think)
  9. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Everybody doesn't have one because 1) Snorkels aren't exactly the most beautiful thing(to yuppies) to add to your truck 2) They cost a lot if you dont build it yourself 3) Most people dont go SCUBA diving in their truck, so they dont need one, I usually stop once I cant see the tires anymore(usually[​IMG]) 4) And most people dont like to hack a big hole in the fender[​IMG]. If your going for waterproofing, dont forget the plugs and wires, Jacobs makes a set of sealed wires. Get a Optima battery. Seal the distributor or at least cover it, remember it still has to breath somehow so drill a small hole and install a vent tube. You cant really do anything for the alternator, except make more drain holes so the water can get out faster and easier. Get a electric fan and switch it off while diving in, I heard that the stock type fan doesn't like to play prop and chews the hell outta the raditor and splashes water all over the place. Dont forget to extend the vents on the axles, tranny, and t-case. If your going really extreme look into extending your exhaust exit to above the roofline(so if it stalls water wont get sucked up through the pipes), sealed headlights, even waterproof gauges, wetsuits, masks etc...I think that's mostly everything[​IMG]
    [​IMG]FUN WITH 31's![​IMG]
  12. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hey there Blazerguy, thanks for the referral! I built my own snorkel for about 25.00. Like they say, the hardest part (on the nerves) is actually cutting the hole in the fender. I admit I went to the extreme, but after wrecking a motor in the mud races up here one year, I swore it wouldnt happen again! I have never been in water that deep, the motor that I wrecked ingested a lot of mud and water from the splash under the hood when I hit the deep part of the pit. I will probably will never be that deep either, but I have waterproofed the motor to the point that if I do run into something unforeseen (like a volcano erupting and I have to cross a raging river aka Dantes Peak) I can be fairly sure I am safe. Of course I dont hold much faith in the motor staying running if it was completely submerged, but the occasional large splash under the hood will not stall me. The points mentioned in the posts above are very good ones. My distributer is regasketed with silicon, both ends of the wires are sealed with Vaseline, the diff and t-case vents are up under the hood, and I installed electric fans. As for the interior, there is no way that I can keep water out, so I just turn off all the electronics, and make sure it can drain asap. Dont turn anything on until its completely dry also.
    Good Luck
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
