snorkle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Aug 1, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    IJust to start, I run in the mud about 95% of the time. That stated.
    I was thinking about running a snorkle up into the drivers compartment. Anyone ever done this?
    Snorkle to keep clean air going in only, no for fording depths, but that is a plus on doing this.
    Ken H
  2. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Look at the ORD Blazer. Stephen has his inside and just under the dash.
    <font color=red> Bill, "Shop Rat" </font color=red>
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    is this a daily driver is, because a few days ago i had a post about running fresh air and one idea i had was to run it to the cab. the only problem with that is the gas fumes that will enter your cab and make ya stink stink like gas real bad. if it's a mudder only go for it. or one good idea someone had was to run the intake to the cowl area but you might still suffer from the fumes because if your vent fan. Or check out mtpockets rig he used a snorkle from ARB for a rover and made it work.
