snorkle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big B, Sep 21, 2000.
  1. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    I have a non fuel injected motor and I want a snorkle were do I get one can anybody tell me thanks Bruce.
    bigb4x4.coloradok5.com
  2. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    Does a snorkle do anything for a gas enginge w/o fuel injection. I thought they were primarily used on diesels.
    '79 Guy
    1 Blazer - 7 Children
    http://79guy.coloradok5.com
  3. They work on any motor as long as you seal it all up very well.My budy runs mud bogs and has a snorkle on his burb,
    he also runs an MSD marien ignition system disrtibutor and all.Seems to work good for him,by the way he runs a blown 540 big block chevy!!!Man that would be nice in the K5!!!LOL
    IF IT AINT BIG IT AINT BAD!!!!!!
  4. Grim-Reaper
    7,385
    Atlanta
    Two big gains with a snorkle and they have to do with getting good air not performance. They run them heavy in Austrailia to get the intake up high because of the dust. Their roads are so dusty that if you were running the intake in the stock location you would pack an air filter up to the point of not working in a couple of hundred miles. The second is to avoid sucking water if you have to cross some deep water. If your not crossing water or running dsirt roads then you would get your best performance by using the stock set up that pulls air from just behind the grill. it's more of a straight shot and has a ram air effect at hwy speeds. This was one of the best things I did on my 75. I was having a ping problem that turns out was mostly caused by a restrictive factory air cleaner and hot under hood air. I used a stock 85 aircleaner and the factory duct and the problem is gone.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  5. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
  6. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    i put a snorkel on my rig over the summer simply to get the cold air intake. cold air mixes better with fuel better than hot air, hence better fuel economy and a few more horses. i bought mine through a shop in ohio, peters off road. it is an arb safari snorkel for an 80 series toyota fj40, which as you might guess was not cheap. ill just say it was under $300. the way thumper went with the pvc pipe works just as well as the one i have.
    happy snorkeling,
    MTPockets.
  7. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Hey thumper you should put the plans on the net so all of us diy (do it yourselfers) can make one. Just a thought...
    Damn colors don't work!
  8. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    <font color=red>yes</font color=red><font color=blue>they</font color=blue><font color=green>do!!!</font color=green>[​IMG]
    WK
  9. MTPockets
    Feb 19, 2000
    502
  10. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Nice looking rig! Where'd you get the front bumper from?
