Snorkle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bortz, Feb 11, 2004.
  1. bortz
    bortz Newbie
    Feb 11, 2004
    3
    Alabama
    Does anyone have or know where I can get a snorkle set up for an 87 K5 Blazer? I've tried ARB and Quadratec. No such luck. Any help would be appreciated!
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Do a search, But if memory serve right the kit you need is from a Toyota FJ-70 or 80????? Thats the one they used on Dante's Peak!
    Bill
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    There aren't any aftermarket kits. Your stuck with paying out the ass on a ARB, or make your own...most people choose the latter...
  4. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    not to hijack a thread, but does anyone have a solution to sealing a snorkel setup to the top of a carb. I'm sure I could build a snorkel but the carb has me stumped for a doable solution.
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
  6. bortz
    bortz Newbie
    Feb 11, 2004
    3
    Alabama
    Appreciate the quick replies. yeah ARB is very expensive. Will check the set up on the FJ. Thanks! /forums/images/graemlins/thumb.gif
  7. tomseviltwin
    Dec 23, 2001
    2,065
    Utah
    shop around. I've seen the arb for less than $300. It's alot but yould be
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've been considering a cold air intake kit for a vehicle that still has a 5 1/8" flange but has an airbox. You can find them all over eBay for $50. It'll get you some tubing and some fittings to make it easier to pull the snorkle off your truck for working on it.
  9. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Would it be possible to modify the factory air cleaner housing to be watertight? I was thinking about this the other day. You could run a hose off the horn or take the horn off and make something to use in that hole or to cover it and modify another way. Just thinking out loud here...
    Kris
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
  11. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    This is what I have been tossin around for mine.
    When I pulled the engine from the van it had a 4" spacer under the air cleaner.
    I am going to braze a bar in the middle and bolt that to the carb then attach a tube to that, sorta like a dryer vent hose.
    Cut a hole in the firewall and run it out of the speaker hole, along the dash and up the pillar to the roof. Still lookin into a filter.
    K&N seems to be a good bet.
