so am i beyond redneck? (step suggestion?)
Discussion in 'The Garage' started by Loose Nut, Apr 30, 2006.
  1. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    I need some sort of step to get into my big ass Jimmy. its alot higher then i planned and well.....as it sits ill kill my self getting in it lol.
    Im thinking about taking a chain, and bolting it to the body and using it as a foot hole to get in the jimmy.
    is that beyond gay? or....if i just loop it around my seat braket i can pull it in the jimmy when im driving lol.
    i need something, and i dont think i really wanna go the route of fabbing up a slider with a step.
    any suggestions? Im lost.
  2. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I have the hoopII and love it to death. It bolts up quickly and supports a ton of weight without flexing or stressing the mounting point.
    http://www.carr.com/steps.asp
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    No the chain aint to ghetto/redneck it's better than those crappy chrome tube thingys you see on all the poser trucks
  4. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    yea this isnt a bling bling mall crawler, its a crawler/mudder. Im just looking for a easy way to get in my truck with out getting anything that would make me get hung up.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    a chain !?!?!
    that is about the most redneck thing i could think of :doah:
    lift your leg, like a real man,,,,:D
  6. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    my truck is up here ----------------
    my leg is down here ---------------------------
    im a short stubby bastad!
  7. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    I have the same problem a bad leg that won't bend . I'm thinking about trying to make something using steel cable,make a lupe or with a step. I've seen this done on some heavy equipment.Also might try to make so it can pull up out of the way. Where are you in Md ?
  8. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,951
    247
    Released from Pueblo, told I belong in Southpark
    I have seen stirrups like on a saddle.
    Those chain ladders for escaping from fire.
    I was going to do some removeable steps on the jimmy that slip over the slider and then could just slip off. Wife didn't want to scratch the slider so she got a two step step stool.:rolleyes:
    Just put one of those little exercise tramps in the truck. Throw it on the ground and voila. Here I come flying the thru the air and into the truck. Ding. Dang roll cage.:haha:
    Its your rig do what you like and whatever works. Besides it looks much cooler to use some assistance getting into the rig than splitting your pants from stem to stern because you are trying to lift your leg up that high. Ask me how I know. :rolleyes:
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I think a chain step is a good idea. Just have a good hand on something to steady yourself when it swings away.
    I have been through a few pair of pants getting into and out of the 'Burb, and it really isn't that tall, yet....
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    chain is a great idea since you can tuck it out of the way when its not in use. someone recently posted taking a length of chain, bolting the ends up and welding a few inches of the middles links so that they stay rigid.
  11. 86 Jimmy
    86 Jimmy Registered Member
    Apr 24, 2006
    28
    Aurora, ON
    My idea was to buy or make hoops with a hinge. That way you can fold them under the body and out of the way when not in use. I'm still not even running yet, but when i do make them i'll post it up here.
  12. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    some ole boy has been making the chain steps and selling them the y look ok. just weld the middle three or four links
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yea, you want something stiff under your sole, but will fold-up as you're going over. Then again, I can just see it getting ripped off on the rocks.
  14. 86 Jimmy
    Apr 24, 2006
    28
    Aurora, ON
    Well the idea behind it would be to have it spring loaded so it would naturally want to sit undernearth the body, laying flat against the bottom of the floor. Then just pull it out and have it lock into a down position so you can step onto it. Once you get inside have a simple release to use the spring action to go back to the resting position. I know it sounds complicated, but it would be much cheaper than a motorized unit and there would be no chain there to snag on rocks and trees. Again, I am planning on building one in the near future and i will post up the parts and process once i've made it. :waytogo:
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Advance Adapters has one that fits that description, check it out. IIRC their's could've used improvement.
  16. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    what matt said, weld some links in the middle so they are rigid but it still has floppy sides so if you go over rocks it still folds up to the panels. It would look like this
    \_/
  17. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    nuttin wrong with chain steps. They are 100x less lame than the standard truck steps that 99% of street trucks have these days... you know, the land-anchor type? Its sort of like when you see a truck with lights mounted under the front bumper. Doesn't matter what else the truck has on it, you know its a street queen.
    j
  18. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    The chain works great. Weld up a few link or put a small piece of tube over it. Mount it to the seat brackets or just inside the cab. Before you close the door just pull the chain step in the cab with you. No snaggys or landanchors.
    Eric
  19. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    lol thanks, i think ill try the chain out :P but yea like someone said lol i can see it being a shin buster of you dont have a good hold on something hahaha
  20. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    This is one the back of my ambulance/worktruck. If I ever get enough lift, its going on the driver side.:D
