So, anyone else F' up their 14 bolt like this? *pics added*
Discussion in 'The Garage' started by afroman006, Sep 7, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    So, anyone else F\' up their 14 bolt like this? *pics added*
    Last night I was pulling out of a parking lot, and gunned it and the rear started vibrating really bad, I thought it was just wheelhop and laughed it off then jumped on the gas peddle again in traffic but the vibes continued. Drove for about 1 minute and parked got out and look under. The driver's side u-bolts had come loose and the spring perch was sitting about 20 degrees away from the block. The kicker was, the other side was still attached tightly. Upon closer inspection, the pumpkin had turned upwards with the driver's side tube causing a hellaciously bad angle on the pinion. I couldnt see very well because it was dark, but it looked like the passenger side tube somehow turned inside of the housing, causing them to be at different angles. I was still able to drive it home, and it hasnt been gushing fluid, but some gear oil has dripped off the bottom of the pumpkin. As soon as I get my puter un-f'ed up, I'll post pics (yes, my puter and my burb f'ed up on the same day /forums/images/graemlins/angryfire.gif). This has me peeved because now I'm a broke college student living 200 miles away from my shop. Luckily, I have another 14 bolt housing at my shop, but it'll need new spring perches. Man this makes me wicked pissed. The only complete spare axle I have is a 14 bolt SF in another truck that is not running so I may yank that one, put it in the burb, take the burb back home, take my 4.56's and detroit from the fubar'd axle and put them in the new housing, then put my hubs and disk brakes from the fubar'd axle on the new housing, as well as spring perches. This is all kinda strange too, I had just drove almost 800 miles round trip this weekend and the damn thing finally let go when I had gotten back to school. So, anyone ever had anything like this happen before?
    Here you can see my new driveshaft angle
    Here you can see how exactly the driver's side tube and differential is sitting right now
    This is how loose the u-bolts got
    This is what the u-bolts should look like
    Here is the passenger side, still intact
    Here you can see how far the axle turned. Before the incident, the T-fitting for the brakeline was about 1/2" away from that wertical bracket, now its about 6"
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Re: So, anyone else F\' up their 14 bolt like this?
    having the axle housing shift? Not me personally heard about it happening. GM in their infinate wisdom press fitted the axle tubes into the pumpkin. only solutions are:
    Axle truss
    tube weld (weld a bead between the axle tube and the pumpkin).
    Axle locator (put some arms on to help locate the axle).
    Dunno what caused the u-bolts to come loose-maybe add a ny-lock on top of that?
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, Richard (chvyhs) on here, had his do it at Blazerfest this year. I had to tow him back to his house.
  4. afroman006
    Aug 21, 2002
    2,876
    I dont know what made them come loose. They had been there with no problems for the 4 or 5 months I've had it in there. I'm thinking I might do the truss routine, but I wont be welding the tubes. As good as I know it would be, I know that you would prety much have to heat the whole damn pumkin to red hot to make sure that the cast iron doesnt crack, because if it cracked, I'd be up [censored] river, not creek, river. The only concern is time. Yay, more axle fun... /forums/images/graemlins/angryfire.gif If only I had a rocket propelled grenade... /forums/images/graemlins/whistling.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can weld to a diff just fine. See my anti wrap bar post about that one.
    Lots of people weld to differentials.
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    [/ QUOTE ] Did you re-torque everything after about 100 miles after the install?
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    The axle tubes are pressed in and then they plug weld the housing and tubes together. I'd drill out the plug welds on the side that turned and re-weld them. The diff housing should be ductile cast which takes to welding a lot better than regular cast. I'd still pre-heat the area a little, but it shouldn't crack.
    Rene
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    TORQUE BABAY!!!!!!!!! /forums/images/graemlins/peace.gif
    We had a '02 cummins with 42s at work, he balooned the u bolts, rolled the perches and block, and broke the center pins, it was ridiclous.
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Seen it 3 times 2 different rigs both Big Block power and in the mud.
    72 K5 with an old Eaton diff and 38" boggers.
    1st time just spun the tubes in the perches.
    Rewelded them good and tight and spun the housing on the tubes. Now verything is welded solid.
    The other was In a 70 something Ford with a D70 and running 44's.. spun the housing on the tubes.
  10. afroman006
    Aug 21, 2002
    2,876
    No, I never checked them with a torque wrench, but I did use a normal wrench. I just found this strange because I had been driving with no problems for about 6000 miles, 800 of which were this weekend. I think it'd be easier and cheaper to just build the new housing I have. What sucks is, my truck is nothing extraordinary. It has a bone stock TBI 350 and 4.56's with a detroit and 36" TSL radials. Hardly an axle busting setup, especially on pavement. Would I be able to just weld the housing with my MIG plain wire, or will some different kind of wire be needed? I dont have a buzz box, just a MIG.
  11. afroman006
    Aug 21, 2002
    2,876
    Re: So, anyone else F\' up their 14 bolt like this? *pics added*
    Pics posted at top.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think the next time I have the welder out, I'm welding my tubes to the pumpkin. Even if I only tack it, I don't want to take any chances.
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Your diff is already welded Tim...they all got welded when they were built. If you look at the outer ends of the housing where the tubes press in, look inboard an inch or so and check all the way around. You should see what looks like an ugly spot weld on steroids. That's a Rosette or plug weld...
    I'd guess the loose U-bolts greatly contributed to the problem with this diff. It would have been able to rotate some and shock load the tubes...
    Rene
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah I know, they're plug welded. I meant welding the tube where it enters the diff itself. Having broken those plug welds in the past, it sucks. That was my 12 bolt though...and the R&P had locked up to cause it after the pinion bearings failed.
    I see what you're saying about the shock loading from all that movement. I generally check my junk quite often, especially when I get new U bolts, because they will stretch.
  15. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The mild steel tubes don't like to be fully welded to the cast center section. I reccomend a tube type truss for anti tube twist.
    I think something like this can do very well with out fully welding. The mild steel expands and contracts (with temp and load) different than the cast center so the welds will most likely crack (read fail). I would not go with the full weld route.
    my .02
    as a side note Rene (tRustyK5) is a weldor by trade so I would go by what he says to begin with.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Maybe I'll just leave it, it's lasted this many wheeleies fo far. /forums/images/graemlins/rotfl.gif
  17. afroman006
    Aug 21, 2002
    2,876
    Now I'm leaning more towards the truss only route. That's like 5 people that have recomended NOT full-circle welding. I think its new shock mount time too /forums/images/graemlins/whistling.gif
  18. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I would get new U" bolts and nuts, Torque them to 140ft.lbs.A drop of red Loc-tite on the threads. Maybe do a shackle flip tp get rid of those rear blocks also.
  19. afroman006
    Aug 21, 2002
    2,876
    I have a shackle flip. Those are only 2" blocks. I planned on doing the loc-tite routine though /forums/images/graemlins/waytogo.gif
  20. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    The blocks kinda defeat the purpose of the shackle flip don't they /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
