So are 6.2 heads ever NOT cracked?
Discussion in '1982-Present GM Diesel' started by uglytruk, Jan 21, 2007.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I was hoping to use the 6.2 heads off my clanking '86 Banks, but keep hearing about cracked this and that. They're headed to a 6.5 being donated to me, and to be re-built, (the heads were real bad), and mine ran OK 'till it snapped something...
    Thoughts? The friendly machine shop said New blanks are $300 each, but I'm not that rich...
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Heads cracked are not that common, you still want to check any head you want to reuse but I wouldn't say it will be cracked.
    On a side note, if you end up needing heads :D
  3. uglytruk
    Oct 24, 2004
    1,329
    Welcome back to the pack...
    Heads? I may need some stinkin' heads... :D
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    mine weren't cracked.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    FWIW, I had my heads checked at the machine shop ('91 6.2) and the dude said one had a hairline crack in it but passed the pressure test so should be fine to run. I plan on going for it because I can't and don't want to afford new ones. I guess I'll just smack myself when something grenades:doah:
  6. uglytruk
    Oct 24, 2004
    1,329
