So exactly how strong is the ol' 208?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, Feb 11, 2002.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    So exactly how strong is the ol\' 208?
    All the responses here were quite surprising. Since I don't crawl up walls and mountains, it sounds as if ya'll think the 208 is worth keeping. Is it? Will it hold up to towning around 2 tons(cars) in a lifted truck with 35's? I'm not worried about the tranny in the least. The rebuild took care of that. If ya'll say keep it, I'll shop around for a better price on the rebuild. All I hear is horror stories of how the aluminum case cracks. But, then, the guys telling those stories were halfway up Mt. Fuji, north face. Snow, ice, pulling cars out of ditches, maybe some sand, dunes, trailriding, nothing fancy. 208 ok for all that? Be it stronger than I really think???<P ID="edit"><FONT class="small">Edited by NewK5Guy on 02/12/02 02:18 PM.</FONT></P>
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Re: Tired old 208 needs severance plan.
    No, the 241 case for the 89-Up Blazers/Suburbans is still on the right side (front output). From what I have heard, it is a bolt-on affair. Just make sure you get the mechanical speedo version (89 only I think), the later ones were mostly electronic speedos. $1600 for a rebuild?? You can get a rebuilt 208 case from Boyce equipment for like $700!!!! And they're not known for good prices! You need to shop around and find a better shop...sounds like they are trying to screw you...and I don't think there are any lower gearsets for the 205 - you would have heard about them by now! I believe that they used the 241 case behind 3/4 and 1 ton dodges, so is more stout than the 208...it's no 205, but at least you get to have a 4 low range - the 205 is pathetically high for a "low range"...
    Good luck with the search. Personally, I think I am going to wait til the 208 I have blows up (192,000+ so far) and then get a 241 to replace it...
    Keith
    So Cal Big Dawgs
    President
  3. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i bought a rebuilt 208 from boyce equipment shipped 2 my door for $800 and it has worked great.
    i only have 2 thousand miles on it. i swapped a junkyard case first, but it kept popping out of 4 hi when hard on the gas, so when i put in the new crate motor and tranny, i went for a new case as well.
    i would definetly do it again. the people at boyce were great
    good luck
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  4. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    I have a 208 from an 85 K5 that had 85K on it before the tranny blew. The t-case was working fine, but I don't need it because I went with a sm465/205 combo.
    I am just down the road from you and actually will be in richmond this week if you could use it. It would be a lot cheaper than your 1600 fix. I would be more than happy to part with it cheap. What do you say??
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You can get a rebould kit from O'Reilly Auto Pats for a little over a $100, and it takes only about 4 hours to rebuild. The hardest part is pulling out of the truck, but still is very easy.
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  6. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    Re: So exactly how strong is the ol\' 208?
    ttt
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A NP208 is not a bad tcase if you don't put lots of power threw it. I wouldn't go mud racing or hardcore rock crawling with one. I have a 208, and it has about 150k and it is fine. It has been me and my dads hunting truck, offroading truck, daily driver, cruiser, etc. I have had to tow with it in four wheel drive in the snow and mud before and it did just fine. It sits behind a 300HP Chevy crate motor now and has been fine for about 20k behind that. If you are going to put in a big block or a hot small block you might want to change to a 205, but if not the I don't see the reason to swap. Just rebuild it with a new chain and take care of it and you should be fine.
    My Chevy isn't broken, its just out of gas.
  8. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    My 208 is behind a 6.2 diesel. No need to worry about big power there! I do plan on turbo'ing it next year so the torque numbers will go up. A rebuild doesn't sound like a bad idea now.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    A buddy just bought a rebuild kit off ebay for $120 for a 208, and then he is going to get a new chain which is another $100, so for $220 and a couple hours your tcase should be just fine for a long time to come.
  10. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    What part of Richmond do you live in. I'm out in Goochland. Its nice to see someone else from Richmond.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey randy
    long time no see
    send me a shout man, we still need to get together
    Later
    Just tap it in...tappity tap tap...
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I'm not a fan of the 208, if for no other reason than the slip yoke. Slip yokes suck no matter how you look at it. They are so bad that I am willing to use the np205s crappy "low" range just to get a fixed yoke. Of course I like the 205s bullet-proof qualities too. chain drive doesnt turn me on either. My np205 cost me about what the rebuild parts these guys are talking about, especially if I sell the 208 when i am done with it! Just an option...the ONLY real down side is the sorry low gear.
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thats what axles gears and doublers are for
    formerly 77chev
    still a jerk though
  14. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    I couldn't agree more ESPECIALLY about the slip yolk. I don't know what to do right now. I'll probably just rebuild and suffer with the slip yolk. If I could get the 241 I need for a decent price when the time comes, I'd do it instead.
  15. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    Just south of Richmond. I live where 95, Jeff Davis(1/3010 and 150 intersect. It ain't the greatest side of town, but it was all I could afford when I moved in.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I personally don't care what my low range ratio is.
    With my current 700R4/NP 208, I run 4 low and 3rd in the tranny.
    When I get my SM 465/NP 205 in, I'll just run 4 low and 3rd in the tranny instead of the top gear.
    Low range lowers your wheel speed anyway. I don't do anything even close to, "Crawling". I usually have my valves floating all the way in and all the way out of the woods. The only reason I use 4 low is to ensure I'll have enough power at the wheels. I don't care if it's 2.62 or 1.96 to 1. Makes no difference either way. In fact, 1.96 probably is an advantage.
    Tim
  17. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I run 300+ hp through a 208c and I have never had a problem. I haev had it high centered on the tcase and had it up to about 5000rpms in 4lo... I have never been to moab so I dont know how they hold up to the rocks bashing them....
  18. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i dont really worry about the case bodys strength...its the slowly stretching chain...and that DAMNED slip yoke that makes the 208 lame. Once I swap my new 205 in for the 208 I have now....I'll never have a slip yoke in any off-road rig again.
    J
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I couldn't agree more about the slip yoke being crappy.
    Tim
  20. biltntboght
    biltntboght Registered Member
    Jan 9, 2002
    37
    Medina,Ohio
    What's wrong with the slip joint??
    As you travel on thru life whatever be your goal keep you eye upon the donut not upon the hole
