so how do i know if iv blown a shock...
Discussion in 'The Garage' started by spincast375, Oct 3, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    i was muddin with some friends and i hit this one rut pretty hard and theysaid they may have heard sumthin pop. now i didnt notice anythin til recently the blazer seems to be tilting to the right front. that shock has about an inch of paint thats been chipped off where the top and bottom meet. when i go over speedbumps at school i ride the left tires between the bumps but i hear the right front kind of crunch if i go over them too fast...
    might also be noted that there seems to be alot of oil leakage close to the right front shock(mainly on the leaf spring below it) although i think this is an unrelated issue.
    so does she sound blown?
    if so, what do i need to know when i replace it.
    should i do two at a time?
    thanks
    jake
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    probably something other than the shock- the truck shouldnt be any differently situated because of its shock.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    bet you broke a leaf
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Unbolt the bottom of the suspect shock, and push up on it, if it compresses easily, it is toast. For a comparo, unbolt both front shocks and cross check.
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Shocks don't support the weight of the truck. A sagging corner indicates a broken leaf or something similar.
    A blown shock will typically have fluid weeping out of it....
  6. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Yeah you broke something else. The others are right in saying that if you only blew a shock, the ride should have only softened up a whole lot on that corner because the blown shock would be letting the suspension move freely now. If it's listing there like you say it is, you had to have broken a leaf spring.
  7. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    OK guys, a shock is not designed to support the vehicles weight. HOWEVER,good gas shocks are compressed when installed, and when you cut the restraint,that compression force contributes to the lifting action of the springs. I personally have seen new shocks raise a vehicle, not as dramatically as air shocks, but noticeable.The post asked how to tell a shock was bad and I answered.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    True to that, gas shocks do push outwards.
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    heck yes they do, my bilstiens were a PITA to install because of that :D
  10. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    after careful inspection i can find no indication as to whether i have a broken leaf spring... broken leaf, seems like it should be pretty obvious. but idn.
    i'll probabl;y take the shock off and test it but whats a broken leaf look like
    lol i know thats prolly a dumb question but there it is
    tks again
    jake
  11. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Look for a vertical crack in any of the leaves....it's not always that easy, since the leafs are usually covered in crud.
    You may have to pull the spring out....remove the center spring pin and see what leaf falls out in two pieces instead of one!!!
    :eek1:
