So how many people have had the need for a snorkel?
Discussion in 'The Garage' started by milspecjimmy, Feb 3, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    how deep was the water, and do you think a fording kit would have helped?
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I can see a need for a Snorkel but not for water, More for the fresh air and maybe less dust, And then there is the cool factor /forums/images/graemlins/thumb.gif
    Eric
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Need more than snorkle.Igniton won't run under water.Computer{if got}needs sealed,sterios get wet,If doors seal tight lots of trucks float.They do look trick though and help survive quick dip,but,every thing has to be sealed for long dives. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  4. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    ive blown through a few puddles and hydro locked my motor. nothing else got messed up and ignition was fine. im just wondering what people have done. and i have 6 vehicles that have full fording kits, water proof every thing and can take 6-9 feet of standing water. /forums/images/graemlins/thumb.gifmilitary stuff rules
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I've gone through 4 feet of water, but not for anything more than a few seconds worth. I'd do one, but dont know where to start really. I've injested water, but not enough to hydro lock. I worry about it too sometimes. You'd need to seal everything, floatation isnt too terrible that I've found. Dont forget to extend the breathers. But I know the Auto trannies do have that vent hole on top. havent figured out how to vent that yet.
  6. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    I don't have a snorkel but it might have come in handy a few months ago when I was going through a fairly deep mud/water hole and slipped into a rut up to my headlights. The stock aircleaner assembly/snorkel was about an inch above the water line. I made it out with a lot of help and later found out the only damage done was my fuel pump died. Changed all the fluids and it's been pretty happy since.
    Unless it's a deisel I don't think a snorkel would help too much for most water crossings.
    And for the one who mentioned the vent tube for the transmission all you need is some hose routed to a higher point. It's been covered before just do a search. I had luckily routed new vent lines from both axles and the trans/T-case a week before my unplanned swim in the k5.
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Here's a pic of when I hydro-locked my first Sub.
    Too Deep?
    I doen't take too much water to lock it up if you don't know any better (like me back then). It was an '82 diesel. I hit the water too fast and it all got sucked into the stock snorkel that pulls air in by the headlight. Supposedly if you go at a slow steady pace the front of the truck will make a bow wave that will keep water at a lower level in the engine compartment. If you stop you can run into problems when everything levels out.
  8. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i have the need for one. i go to the badlands orv park and ever since the water went over my hood for the first time, i built one and slapped it on. here are some pics. click on the badlands links and check out some pics from the badlands. there arent n e in there of it underwater, but once i get it fixed, ill get some pics up of it underwater.
    www.geocities.com/yz80foxracer/index.html
    NITRO
  9. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thanks for the transmission advice.
    As for gas vs diesel, the only difference is the ECU and the Distributor.everything else doesnt matter. I think the largest amount of water I had dumped into my engine bay was from the mechanical fan acting like a propeller.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have had the Fraser river flowing up my windshield,
    water in the cab flowing into my Dayton boots.
    if you are gonna play with water crossings a snorkle is a good idea.
  11. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    I didn't think I needed one until I sunk my burb to the hood in a mud hole!/forums/images/graemlins/shocked.gif Cost me an engine./forums/images/graemlins/frown.gif I will eventually put one in when I finish all the other mods I have on my list.
  12. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i am thinking of making one of 3 inch PVC, and relocating the over flow rezivour
  13. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Mike-LOL I just watched the video of that the other day, where they were pulling you out and draining the doors /forums/images/graemlins/grin.gif
  14. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I ran through some holes about 5 feet deep with my flatbed. Water came over the hood and about 2-3" up the windsheild, looked really cool on the inside! Never drowned out.
    Here is what I did with:
    1)Stock "tall" air cleaner, knocked snorkel off and opened up hole some. Turned around so opening draws air from distributor area.
    2)Use di-electric silicon grease on all spark plug boots, high quality wires as well.
    3)Electric fans, manually turned off for water crossings.
    4)Keep a steady somewhat slow speed and it WILL keep an air pocket under the hood for some time.
    We were playing in a old sand pit that day. Lost track of how many times I played submarine. Don't have any still pics, used the cam corder for that day.
    Hardest thing to flush? Power steering gearbox.
  15. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    I had a wet air filter a few months back. For some reason I get the mud urge every now & then, must be from growing up in OH. Anyway, water (mostly) and mud to the level of the floor-as in the floor was under water when I was stopped. This is w/ 5" lift & 35s, no doors lets the water in. I think a snorkel would have helped there, but for 90% of what I do I don't need one.
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    A few years ago I had Emmett in a river during a 4x4 night. I was in so deep that the water was about 6-8 inches above the bottom of my seat(where your arse goes)... The water was up over the floor shifter, ashtray, radio, etc. I went another few feet and then it died. I was damn lucky it did too because the kid that was walking in front of me to gauge depth had just fallin into a deeper part. If I had gone another 3 feet, I would have lost the Jimmy!!!! The water was up over the hood in the front.. I got pulled out by a new SD dually Ferd and when we got it on flat ground and emptied out the cab I starte don the engine. When I drained the oil, I filled a 5 gallon bucket! We pulled the plugs, and a ton of water shot out of every plug hole.
    After we changed the oil/filter and dried off the plugs, It started up after cranking it a little and I drove it home! /forums/images/graemlins/smile.gif
  17. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I could have used one on my old Blazer. I went charging through a puddle and sucked up some water. Made for a great picture and the following 12 hrs working on the truck /forums/images/graemlins/shocked.gif .
    A snorkel is high on the list of things to do on my Jimmy. The piece of mind that you're not going to suck in water that splashes up is nice.
