so how well will a 14Bff hold up welded?
Discussion in 'The Garage' started by milspecjimmy, Apr 2, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i want to weld up the spider gears in a 14bff and run it on the street, how strong are they? its going under my blazer, and will be mainly street driven. and could possibly see 35-38" tires. whos done it and what broke if any thing
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i think it was said that after long term use they start to get broken if you use the welding between the teeth method.ive heard the strongest way is to weld the whole thing so it cant move side to side in the carrier.with it welded in between the individual gears ive heard it has slight side to side motion and eventually falls apart.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Mine has been welded for about a year and a half, and I have not had any problems at all with it.
  4. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    so your saying that if i weld the gears to the carrier and baisicly make it a spool it will do ok for a while? i plan on buying a locker, but not for a little while.
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If you weld it up like a spool with good clean welds, it will last indefinately. /forums/images/graemlins/thumb.gif
  6. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I had welded mine like the article on the home page. I drove it like that for nearly two years on the street and when I pulled it apart I found the side gears were starting to crack...another couple of weeks and there would have been broken side gear teeth floating around in the oil.
    If I was gonna weld one again I'd weld the spiders solidly to the cross shaft.
    I wouldn't weld anything to the carrier itself, or you won't be able to use a locker later...
    Rene
  7. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i am thinking i am going to weld the spiders to the cross shafts, what abotu axel breakage? any thing i should worry about there?
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Anyone have any pictures of a 14bolt w/ the spiders welded to the cross shaft? I want to do this to mine too...but not sure what needs welded where.
  9. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The axle shafts aren't a concern...they're freakin huge!!!/forums/images/graemlins/thumb.gif
    Rene
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I solidly welded the side gears to the spiders, basically filling up every void that you could get to with a welder. So far it is going on 3 years and no problems. I just had the cover off last week and they looked fine while running 35" tires. Recently switched to 38's which should really test it, but I'm not worried about it at all.
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Kidjethro did mine, he welded the spiders to the cross shaft and then welded the spiders to the side gears. It's not going anywhere... /forums/images/graemlins/thumb.gif</font>
  12. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Just outta curiosity, if it is mainly street drive how come you want a welded rearend? It will kill tires much quicker,
    and wont drive that well. I am about to weld up my front Dana 60 because I am going to a ARB in a few months so
    I might as well until then. /forums/images/graemlins/confused.gif I wont be able to turn at all without getting out an unlocking a hub though.
    Later
    -fLeXy K20
  13. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I personally wouldn't run a welded diff in my daily driver (don't really need the traction) but I also don't think it is that bad. The Blazer still gets driven to the trails (about 200-300 mile round trip usually) and you don't really notice it except for real sharp turns like in a parking lot.
  14. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    well boys the ole lincoln 220 welder is comming out to play, i am going to weld the spiders to the cross shafts, and then to the side gears. any tips on taking the carrier out? i am assuming that they are not the same as the 10bolts.
