So I am retarded....Push button starter
Discussion in 'The Garage' started by Poohbair, May 16, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    So I cant figure out why I don't have any keyed ignition power...??? SOOOooooo I am tired of looking for the problem. How do I just wire it for a push button starter? Which wires to I get from where, and what do I do w/ them?
  2. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I don't know what the wire colours are but it is easy to figure out with a test light. Should be three wires going to the ignition. One will be hot, one will be ignition on and one to the starter. Basically 'off' is all separated, 'ignition on' is ignition to hot, and 'start' is starter to hot (until turnover). Does that make any sense?
  3. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Its da purple wire!
    Usually the wire to activate the solenoid is purple on GM trucks and cars..might as well by pass the neutral safety switch as well--you can unplug the purple wires from it,(the neutral safety switch)-and run one to the pushbutton,(the one that goes to the starter!)-and run another wire from 12V hot lead to the pushbutton switch..done!... :crazy:
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Don't need it anymore... just got her fired up using the good ol' ignition
