so i finally got arouind to taking the steering box off...
Discussion in 'The Garage' started by tomford, Dec 29, 2006.
  1. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    after something in the steering box broke, (a couple of bolts holding it on) i had the truck towed home and parked it in the yard like i was planing on doing for the winter. well i finally got around to loking into was was wrong, well both high and low p.s. lines broke and 3 of the 4 bolts hodling the box snaped inside and 1 was hand tight.
    it looks like i didnt do any damage to the frame but this wasent the first time it hapened to this truck, the top left bolt hole is cracked, and there is a plate behind it. Is it too late to get the ORD weld in repair kit? does anyone have pics of the install? this spring were putting in a 350 so would that be the best time to weld in the repair patch?
    thanks
    tom ford
    oh yea the pics...
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Drill out the end of the crack to stop it from spreading, then weld 'er up. Throw in the bolt-in brace after that and you should be good to go.
  3. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Mine
    What I did to fix it after I welded it back together.
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    MMMMMMMmmmmmmmmmm booger welds.
  5. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Whatever, if you say so. I dont need to prove welds to any of you.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    In your first pick it looks like like either a crack or a semi-repaired crack from the rt bottom bolt up to the top of the frame. You need to clean that area real good and check it out cause something has to be going on to cause this multiple times. That is unless the box was just loose.
  7. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I do believe the weld in kit goes on from the outside, so the engin being out doesn't matter, i would put the weld on kit on with the bolt on brace, and fix the leak, because oily threads don't stay tight.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have the bolt in and highly recommend it.
  9. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Chill out, brother. If you have a problem with something someone says, please spare us the drama and take it to PMs.
  10. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Ohh... ORD has some pics of the weld on brace. I'm gonna get it. I have the bolt on,but I need more protection.
  11. Slapperbar
    Nov 29, 2005
    2,747
    3
    No one said boogers don't stick.
  12. UseYourBlinker
    Jun 7, 2000
    11,117
    Wooop ahhhh..
  13. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Thick skin in here highly recommended. If your happy with the welds then roll it! Don't let people get under your skin....
  14. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    :haha::haha::bow:
