So I got this York compressor, now what?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Apr 25, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I am not planning on running air tools, I just want a hose from the compressor to fill my tires. I plan on making a bracket and installing it where my AC compressor used to be. Then put a switch on it to turn it on and off. I will put a filter on the airintake and connect a hose on the outlet side. What do I need on the outlet side to make it work, I suppose I need some kind of relief valve before the airhose connection, if not something will blow up if the pump is running without any air being used. I guess what I want is a simplified version of the write up in the Technical section.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are only going to fill up tires take out the check valve from the tire inflator and also do not use a guick disconect on that end. When you hook up the line and turn on the pump the hose will just blow air all the time you arn't filling up tires...quick cheep and easy...then you can worry about a tank and pressure switch later if you want.
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    I am planning on just installing a 125 psi safety valve in the system, that way if pressure builds up while I go from one tire to another it will just blow out the safety valve. Is this OK or does anyone see a problem in this. /forums/images/graemlins/ears.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/crazy.gif
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    no problem with running the safty valve. you'll just sound like a sick cow if it goes off on the hiway /forums/images/graemlins/smile.gif
    you should hit some of the local semi yards an pick up a small tank.
    you still haging around playas?? if you ever come this way, to mexicali/el centro, let me know and i'll show you around. I've been going behind el centinela(some sandunes) in mexicali on sunday eves. it's been a blast...
    later,
    ARQ.
