So I need to do some trimming
Discussion in 'The Garage' started by K30Blazer, Sep 6, 2005.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    Went wheeling for the first time since my new lift and tires this weekend (35 Mud Rover and 4 inch lift on my 87 Jimmy). I need to trim the back of the front wheel well, but the rear was fine. Actually the front started to trim itself. Lol.
    Just sharing. :laugh:
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    That's how it starts :laugh: see the UAV post on how it winds up in the end if you keep going :haha:
  3. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
  4. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    the rear wheel stuffs just fine
    Here is a hill we charged a bunch. I tried four times and made it once. It is just a bunch of loose shale. Around midway you just start to get buried. That is my friends 350 powered CJ with a broken driveshaft.
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    The rear doesn't normally rub the sheetmetal with a mild combo. But, if you look on the inboard side of the tub it was probably rubbing there. Look for a clean spot. Not a big deal on most, but the '73 & 74 used bolts to hold in the wheel tubs and can mess up a tire w/o you knowing it. They were gone by '76, I don't know about '75.
  6. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I am an 87 so no worries, but thanks for the heads up.
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Angle with cutoff wheels & a flapper to smooth it off :grind: , and a sawzall :hack: , and an hour per side and it'll look good and be good.
    Don't forget to BFH your inner fender in :)
    Mike
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine "cured" itself after repeated bashing in the front.
