so i want to do an axle swap
Discussion in 'The Garage' started by milspecjimmy, Dec 30, 2002.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    ok so when i get my axles, what else do i need to get? as far as steering, driveshafts, brake hardware, ect....?
    i am looking at getting the common D60/14bff combo from a cucv or similar vehical
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    might wanna do a search, its been covered many X. or put that in the title /forums/images/graemlins/wink.gif
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Brakes will bolt up, you'll need to either have the Yokes changed on your drive shafts to 1350, or you can buy the Conversion 1350-1310 u joints. The pinion is longer on both diffs, so you might want to have your driveshafts shortend a little bit. If your half ton spring plates dont fit youll need new ones, i dont think i needed them. But for the Diff side of the D60 youll definately need a new spring plate. Depending on what year the 14 bolt came out of, that will determine if you can run the same setup for the e-brake. Youll want to get new bolts. Steering will bolt up, if it is a Chevy front end and not a dodge.. Obviously youll need 8 lug rims. If you want to run 15's youll have a lot of grinding to do. thats all i can think of.
  4. tRustyK5
    Jul 23, 2000
    36,182
    1,388
    E-town baby!
    Perches will have to be moved if the 14 bolt is from a one ton.
    Front driveshaft will bolt up...rear will need the conversion U-joint.
    10 bolt brake lines fit the D60
    Shock mounts on the 14 will have to be changed if it's from a one ton too
    Rim size and caliper grinding is a whole nother post.
    Rene
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    "common D60"........LOL,about as common as finding an a Ford that can beat'cha!!Mike
  6. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    so to be safe i should stick to the 3/4 ton stuff, and just get the conversion u joints?
  7. BLUESMAN
    Oct 3, 2001
    951
    Just "razzin" ya!!If you can find an Dana60,grab it quick!!I only wish I could find/afford one or two!!Think BIG and STRONG!!
  8. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    if i had my way there would be 2.5 ton rockwells under it in a second, too bad it would take more lift than my state allows just to put them in.
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yea i forgot about the front u joint and not needing a conversion joint, I bought the 1350 u bolt style yoke for the d60 then had the driveshaft changed. thats why i said that. but now i remember that someone said the front shaft will bolt up if you keep the stock yoke..... thanks for catchin that.
