so I want to make exaust cut outs, where to start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by supersize75, Aug 25, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I really want to be able to hear the open pipes at least once in a while, but the only cable operated ones I have seen are 2.5 inch or below.
    Any one know where I van get 3 inch ones, or how to make them?? Ideas? /forums/images/graemlins/thinking.gif
  2. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Somebody used to sell them in the back of Chevy High Performance or Car Craft.
    I'd just get some wyes or build your own and use power door lock actuators to open and close them.
  3. dyeager535
    26,980
    FWIW, the only people that I know that have experience with cutouts, say they are a pain. Warp and or rust so they don't work smoothly or at all.
    No personal experience, just what I've heard. They sounded like a pain.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd just get the ones with wing nuts.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Here's one idea: have an exhaust shop make up some "Y" pipes to put behind your headers. One branch would go straight to your existing pipes and the other would just dump. The second branch would be covered off by plates held on with wing nuts. If you had everything made from stainless pipe with stainless hardware, it should last a while.
    Here's the only good "automatic" idea I have. Use a pair of stock "heat risers" to block off the straight exhaust path. You would have to modify them a little to make them close all the way (instead of just most of the way) Then you could use the stock vacuum actuators to open and close them. Ideally, use would use vacuum to open with spring close, but they are set up the opposite way. Maybe that could be changed? The diameter of these isn't real big, though. Mid-80's trucks have a vacuum switch that is electrically operated for the EGR valve. You could snag one of this to give you control over the system with a switch.
    I think reliability will be the biggest issue. Good luck
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    well if you are $$ you could look at getting parts from diesel exhaust brakes
    like pacbrake for cummins B C/ford powerstrokes
    not certain they seal 100%
  7. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    On the TV show Trucks they highlited a pair of cutouts that they put on "copperhead". They were operated by switch and used a solenoid to open/close them. I do not remember the name of the company that made them, but I do remember that they were very high dollar items $$$$$ /forums/images/graemlins/frown.gif
  8. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Open exhaust just plain sucks. I was running it on my '83 for about 2 months. I finally got a used y-pipe on there and a new cat and igged up a muffler and tailpipe until I can afford a real exhaust.
    I couldn't hear [I love Jeeps] with open manifolds and my clothes smelled bad after driving for a few minutes.
    It is fun though to sit next to a ricer with a 6" fart can when he revs at you the you just stab it an nearly shatter the bitch's ear drums. /forums/images/graemlins/laugh.gif
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    a picture is worth a bajillion words....I have the cutout after my cats, and it's not too bad. sounds better than open headers.
    /forums/images/graemlins/thumb.gif
  10. supersize75
    Sep 27, 2002
    2,638
    is that a 3 inch pipe, did you buy it or make it, I guess I will be doing a wing nut style for reliability /forums/images/graemlins/thumb.gif
  11. JaymzLD
    JaymzLD Registered Member
    May 22, 2003
    11
    St. Louis, MO/Laramie, WY
  12. supersize75
    Sep 27, 2002
    2,638
    thanks /forums/images/graemlins/thumb.gif
