So if front blocks are bad, why are rear ones OK?
Discussion in 'The Garage' started by dremu, Apr 25, 2004.
  1. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Everybody says that front blocks will pop out and go flying. I can see where that would detrimental to your suspension, nevermind the passersby.
    But why don't rear blocks pop out? Is it that the rear axle isn't subject to the lateral stresses that the front is (since the front end is what turns)? ... seems like the rear axle would still see sideways pressure when twisted up in the rocks...
    anyway, inquiring minds ... inquire. I didn't think this was quite COG enough but for all I know it'll end up with a subtitle of torsional stress analysis /forums/images/graemlins/laugh.gif
    EDIT: While I own a pair of 4" blocks, they're currently holding down the back of the truck (ie loose in the bed) and I intend in the future to only use them to hold down other things (ie paperweights) When I get the housing squared away for me and the trucks, Karnak The Invincible sees a shackle flip in my future to go with my front lift springs (thanks DesertRat!)
    -- A
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you are right. Lateral pressure is a big issue, in a crawler you are right it will get plenty of lateral stress. You will never see blocks in a rig I own, hunt me down and shoot me if I ever change from that statement. I should note, don't count something I bought and plan to replace /forums/images/graemlins/wink.gif
  3. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Blocks can and do pop out of the rear suspension. It's not only lateral stress but the amount of torque applied to them. If you're considering blocks for the suspension please think about what you will be doing with your rig (street only or actually wheeling) and think about how much money you'll save by doing things right the first time. /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My DD came from the factory with rear blocks.
  5. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I doubt it's taller than 2" though. That's the maximum safe limit IMHO. I'll be running a 2" block for my 63" rear springs IF I need it to level out with my 6" fronts.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you will likely need something.
  7. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I have a Superlift 2" suspension lift with blocks in the rear. What would be a good set of replacement rear springs to eliminate the need for blocks? As it is now the rear sits a little lower than the front with the blocks.
    -Scott /forums/images/graemlins/usaflag.gif
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ORD sells a shackle flip kit that gives 2.5" of rear lift. No need to go with stiffer less flexy springs.
  9. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    y'all that scary ford from last week that had pieces of cut leafspring being used ass lift blocks thats what I thought of when I read this thread /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It is 2", but some Dodges and Fords come with 4" blocks from the factory.
  11. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I had some wierd ass 2" bumpstop looking blovks on my truck, not sure if they were stock or not though
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] he came by last night, drove the truck on the street the other day. my draw dropped. His spindle nut loosened up and death wobbled like mad. On that thing my heart skipped a beat. Hes going to remove that [darn] soon. I hope he keeps up to those words.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I agree, ORD Shackle flip in either 2.5' or 4" depending on your app. is a much better choice the blocks !!!!
  14. bgchvy79
    bgchvy79 1/2 ton status
    Jan 3, 2004
    108
    Moore, SC
    I go to school w/ a guy who has the stock 4" block in his dodge w/ another 3 inch block stacked on top...seems a little bit dangerous/retarded/ridiculous to me... /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif
  15. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Heh..... I ALMOST did that back in the stupider days
  16. dremu
    Feb 27, 2000
    15,968
    461
    Oh, stacking blocks is easy... you just have to use couplers to hook the factory U-bolts to all-thread to lengthen them. /forums/images/graemlins/eek.gif
    /forums/images/graemlins/histerical.gif
    -- A
  17. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    If ord uses spring center pins on its zero rates,which is practically a 1" lift block, why not use longer spring center pins on blocks of 2" or more to keep them from spitting out.
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    exactly the problem with promoting the ORD blocks as 'safe and proper'
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're especially safe when used with grade two centering pins. /forums/images/graemlins/rolleyes.gif
  20. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    My pleasure. Good thing the missus wasn't around when you came by. She woulda had me load you up with just about everything else in the backyard if she had her way......... /forums/images/graemlins/yikes.gif
