So, I'm startin to fall for the Sami
Discussion in 'Other Rides' started by TXsizeK5, Jul 16, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    So, I\'m startin to fall for the Sami
    What do you guys think of a late 80's sami? Do they make lift kits for them? I saw one in action and damn! impressive , rarely got stuck b/c so light, yet pulled out a blazer with 38" hawgs!
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Re: So, I\'m startin to fall for the Sami
    As long as you keep the blazer, go for it. You can get some ramps and drive the sammy up into the back of the blazer and drive it around. /forums/images/graemlins/thumb.gif
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    They are pretty mean little truck with their 4cyl power. I know a couple guys that run them in the 4cyl stock class at the mud drags, and they all do pretty good. You can get some really good super low tcase gears for them too. Good luck!
    Kris
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    for off road only ??? most for the ones i have seen get some toyota axels and a newer geo tracker moters More power cut some metal and get a good rig for low cost /forums/images/graemlins/thumb.gif
    hoo and put in a cage they fold up like a tin can /forums/images/graemlins/eek.gif
  5. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    We used to run into a group of guys with some well built sammys at a wheln spot down here in Spring. A few of the guys put VW rabbit diesels in ‘em and if I remember right they run a shop out of that area doing the conversions. Out of anything with 4 wheels in the dirt out there, those sammys out wheeled just about all of ‘em.
    Here’s a link to some zuk stuff I found a while back when I was kicking around the idea of buying one. I would have bought one but I couldn’t afford a new project back then….hell I still can’t.
    Good luck if you get one.
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    get on pirate4x4 and check out the zuk section. I've helped build them, wheeled in them, and seen them. They rock, but I wouldnt want to DD one. I like my street vehicles with a bit of power and stamina!!
  7. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    hey derek ya talkin about daniels sami? man i've mudded his old one and i was impressed. i'm a fullsize person but man i like em. i drove it all the time cuss he didn't have a liscence so i had to drive him. man the drive is ok. got some power. easy to work on. replaced a clutch like it was nothing. 35lb tranny. lol. but their good. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    jacob
    p.s. keep the blazer.
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Spring over, lincoln locked rear and 31s,maybe a set of 5:13's froma tracker. youd be surprised where that will take you. My buddy has one with a 2.8V6,T5,dana300, yota axles, yj springs all around and 33's. it will go anywhere, but its heavy, 3400 lbs /forums/images/graemlins/grin.gif
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Here is the one I picked up this week.
  10. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    ehh, they are ok /forums/images/graemlins/thumb.gif
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Personally I think in stock form they suck! Peole I know who off road them stock break them a lot. You can build them into a pretty good little rig as said in above posts for lots of $$$$$$. But its like someone putting a 350 and all GM running gear in a Jeep to make it trail worthy. Why go thru all that hassle when you can just drive and build the real thing........... A K5. /forums/images/graemlins/thumb.gif
  12. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Because 1/2 ton axles are bulletproof under those things. You need to go 1 ton on a k5 to be as strong as the sammy on toy or 1/2 ton axles. They also get better gas milage, and tires are cheaper since you dont have to get anything bigger than 35s.
    Dan
  13. zcarczar
    Feb 10, 2002
    2,495
    Im planning on running toy axles and 35's under the sammurai. I figure with dual lockers, power steering, 5:1 Low range and 5.71's in the diffs I should be able to run just about every trail in the desert. That way I can keep the K5 nice and dent free and trash the hell out of the samurai. /forums/images/graemlins/deal.gif
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ]Think about it boss, build a k5, put 1 ton axles under it, a big block maybe, older style transfer case, change this and that, cut fenders... before you know it, how much of it is a k5 anymore? Not quite so different is it?
