So learn me on big block heads...
Discussion in 'The Garage' started by Zeus33rd, Mar 15, 2006.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Just looked up the heads on my 454 today-
    14092360...86-90...oval...OPEN...454 Truck, "peanut" round ports
    So what does all this mean? The oval port, open chamber part I think I understand...But what does "peanut ports" mean? Are these good heads or so-so heads? I realize they aren't performance/hotrod heads, but I'd still like to know what I've got. :)
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    the peanut heads are the red headed stepchild of bbc heads.
    i wouldnt intentionally seek them out, but if i had them in good shape id run them. just make sure you have an intake specifically for the peanut heads. most marine engines run them for low rpm torque. peanut ports are smaller even than oval ports, and would be fine for your tow rig.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Those heads are ok for torque, aint gonna have much power over 4500 though. Heads are divided into Rectangle, Oval, and peanut, peanut are basically just small ovals. Like, really small ovals. They are about half the size of my 049s (ovals) after I did a little porting on my 049s.
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The "peanut port" heads are very low RPM range heads.
    They came in some T/D motors for truck applications and in C/K/R/V trucks too. They give a BBC a power band similar to a diesel engine . Lots of low end grunt but at the exspense of any kind of power over 3,800 RPM's ( actually these heads fall off a little before 3,800 RPM's ).
    These heads are great for towing and motor home applications but not much else . I am not saying that they are a bad design but I am saying that they were meant for a specific RPM range and not much else.
    Tom
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    So, in other words, they suck shiit? :haha:
  6. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    the peanuts are very, very common in the marine industry.. see them quite a bit...
    for a low rpm trail rig, they'd be decent i suppose...
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    peanut port heads are perfect for a low end torque engine, they don't make any HP but torque is what you're after anyways.
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I was hoping you'd reply to this thread. :)
    Anyways, the truck is a dd with a 465 trans....No speed shifting goin on, so hp isn't really gonna do me much good.
    So, since I have these heads, What should I be lookin at as far as cam specs?
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    something small
  10. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    Comp cams makes a retro-fit (or not) hyd roller cam that has 206*/212* duration. The same cam (although not retrofit) is used on sallee chevrolet's extreme4x4 454 engine making over 400 ft/lb at somthing like 1300 rpms. that engine uses a late model block (gen 6 i believe), 4 bolt main. i don know what you have but those numbers look pretty good to me. heres i link i hope it works http://www.sallee-chevrolet.com/frame.html?/ChevyBigBlockV8s/454_xtreme_4x4.html
    "this engine has peanut style high torque heads" thats what they wrote(on the site)
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    How much for the Sallee motor?
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    This is what I have as far as a block-
    14015445...454.......78-90...2 or 4 bolt
    It does happen to be a 4 bolt. :D It actually started out as the Goodwrench 454. Same as what Sallee started with except mine is Gen 4.
    This is the cam kit I'm considering-
    http://store.summitracing.com/defau...eywordSearch&DDS=1&N=115&target=egnsearch.asp
    The least aggressive of the Extreme 4x4 line.
    I would think that that cam, along with an Edelbrock 2161 manifold and an Edelbrock Q-jet would make a good torquey motor. Thoughts?
  13. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yep, the high lift/low duration of that cam looks good to me.
    may have to check valvesprings and or piston/valve clearance, just to be sure.
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    $4,850 (search their site for SC454X ).
  15. stevos67k20
    Sep 29, 2005
    140
    Somis
    hey thats not bad at all. i never did find a price for that engine.thanks
    KidJethro: sounds like your good to go! good luck.
