So let's talk exhaust pipe
Discussion in 'The Garage' started by dremu, Jun 24, 2005.
  1. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Doing my doubler, and so far, every time Stephen says "You may need to look at...", I've had to :haha:
    Well, except body lift and tranny pan clearance, but I've only gotten the doubler within 6" of the floor so far :(
    The passenger side exhaust is routed RIGHT where the '205 wants go ... truck has dual exhaust, but I think it's had custom bent stuff to replace the factory somewhere along the line.
    So... my questions:
    1. Can I do this myself, being handy, having a welder, but no bender? Or should I suck it up and pay a shop to do it? (I'm grimacing at the thought, as I'm already waaaaay over budget and eating Ramen until the first :) )
    2. Can I use that flexible exhaust pipe stuff, or is thjat a JC-Whitney evil thing for hoopties that no respectable person would use?
    3. I presume I would then get some pre-made 45's and 90's and straight lengths, and jiggy it together myself?
    Somehow I don't think the pre-made kits are gonna work around a doubler, dontchaknow.
    -- A
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'd either let an exhaust shop do it or buy some 45's and 90's and try it yourself. Deffinitely do not use the flexible exhaust pipes.
  3. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    When I updated my 72s engine I wanted better flowing exhaust, but I didn't like the dual exhaust system some previous owner had installed, for the very reason you stated. It is too close to the transfer-case.
    So, I had it replumbed with a cross-over to a single 3 inch. Works and sounds great! Of course this doesn't address your cash outlay concerns.
    Also, I have never been a fan of the flexible exhaust tubing. Virtually all I have come acrross, leaked.
    You may find that Flowmaster or some other exhaust manufacturer offers a pre-bent system for your application. You could use that and go the extra step of welding all the joints.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    What I did on my old '79 was take it into the shop, piad them ~$100 to bend the pipe and hang it w/ clamps. I then took it home, pulled it down, cut it up, put an H-pipe crossover in it, and welded it all back up, and then hung it all back up as 1 peice.
  5. dremu
    Feb 27, 2000
    15,968
    461
    This is what I figgered.
    I doubt they have one for a '74 with a doubler, is the problem :haha:
    Local shop it is. Thanks all!
    -- A
  6. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    just a question, this kid is running those flex exhaust lines straight out of his manafolds into tips, whats wrong with them???
    i knew they had to be too good to be true when he was putting them on, but whats wrong with them
    lol just a tid bit of info, he is running them on a cadalena (spelling??) witha 455 in it, and he is also running a flame kit with them. lol intresting guy, wouldent know him if it wasant for auto tech class.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Piecing together an exhaust system isn't that hard and you get to put it exactly where you want it to go. Plan out your routing, figure how many 180's it will take to get there, and order at least one extra from JCW.
    The simple trick to aligning all of the bits is to buy hose clamps to fit the exhaust tube and put some windows in the bands. Bridge the joins with the clamps. When you have the alignment you want, tack thru the windows. You'll loose a couple in the process, so have spares.
    Also recommend flanging the system so that you can pull it out in sections.
