so my starter and a tie rod broke today
Discussion in 'The Garage' started by BranndonC, Feb 11, 2006.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    all without leaving the driveway :mad::mad: i guess i'm glad i wasnt on the street. though. dont know why the starter crapped, and the tie rod needs the spacer thing to make it not go in as far so it has more play, i didnt know that at the time of installation. Pics to come later, video for now.
    http://www.youtube.com/w/Broken-parts?v=SyvOx9aYHog
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    wow, never seen an end do that before:eek1: i have seen a sector shaft on a f450 stupid duty brake though. was sitting in traffic and the guy was in front of me, he went to turn around and suddenly he had no steering. i got out to give him a hand and seing that scarred the crap outta me, if he was driving that coulda killed him, me or anyone else on the road:( as for the starter, looks like it wasnt shimmed right. did you check that it was correct when you installed it? sometimes you cant hear it being off but it will be enough to tear those things up.
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Must be the LED taillights. Dude, you created a Frankenstein, its self destructing.
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    never shimmed it, how do i know how much to shim it?
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    best bet would be to get a manual for the caddy the motor came out of. no telling how much it needs to be shimmed. autozone has shims cheap in the help section but you usually get them free with a new starter. also theres usually a little metal rod that comes with the starter and shims. this is how you check if it needs to be shimmed. you push it beetween the flywheel (the valley of the fluwheel teeth and the tip of the starter gear) when that slides in easy but still makes just a lilttle bit of contact to both its in the right place. heres a quick drawing from paint to illustrate what im talking about.
    P.s. Dont you just love the work i did in paint?:D
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The shaft the gear is on, 1/8th inch from the flexplate gears. I use a 1/8 allen wrench. For a SB Chevy..........Caddy????
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I didn't see a starter brace in the video.
  8. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    haha my starter broke like that too. i just bought one at kragen and it works fine. if i'd go bakc i'd just buy one of those smaller starters for the weight factor.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    What spacer are you talking about on the Tierod? I dont have any spacers and now you got me worried. Maybe he meant the starter spacers and got confused. Anyone?
    Ira
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    lol it must be hard being a starving artist!
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok, let me try and explain the best i can.
    the threaded shaft on the tierod went in the hole on the steering arm, and the hole on the pitman arm too far, therefore not allowing it to pivot or move at all. they sell tapered cone shaped spacer things that you put on your shaft to make it thicker(lol) so it doesnt go in as far, which lets it in turn have more play to move around.
    this really depends on your tierod ends though. my old ones were whaped like this <> fatter in the middle which did the trick, my new ones were shaped like this /\ no bulge in the middle so when i tightened them, they went too far.
  12. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Never seen anything like that before.
  13. sandawgk5
    Oct 28, 2003
    6,881
    I see I will have to go check mine. I dont think mine is sucked up that tight. I have the ends that come with the ORD crossover.
    Ira
  14. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    aim for a .030" -.040" gap for the starter gear to flextplate. and don't forget the brace.
  15. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dont have a brace, should the new one have come with one?
  16. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    nope. there was somoene on cb7 that had 'em though.
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thats what Caddies used to be all about. They were heavier and more $, but some of that was not in plain sight. A late '70s chevy starter doesn't have a brace, my '79 Seville with the Olds 350R motor has a longer starter, more windings=more torque and durability. That starter is also heavier and would probably break without the brace. So I'm not familiar with the Cad 500, but I suspected a brace might be missing.:D
