So My Water Leak is Back(Long)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Feb 20, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah its been fine for a month or more but I go out the other day after I came out the store and noticed some green under the truck. Sure enough its the same leak as before.
    Its leaking down the front of the motor on the trucks right side. It runs down the axle vent tube then onto the axle itself.... Since I work at a shop back home, I put it in the air over xmas break and had one of the other guys take a peak. He couldnt find anything, checked the waterpump and determined it was fine. Ive pressure tested this thing seems like 10 million times with no success. Its starting to piss me off. I guess Ill get a tester tomm and check it again..Any ideas on what it could be? /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/1zhelp.gif
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Where is your radiator overflow? Is the rad cap good?
    Bill
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Hmmm never thought of the overflow tank...Ill take a peek tomm and see.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If it sits awhile sometimes it dries up and you could look for the leftover residue to see where it came from, would leave a witeish trail. There isn't too many places for it to come from , maybe water pump or gaskets, freeze plug etc. /forums/images/graemlins/k5.gif
  5. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Did you check water pump to block seals on both sides? I have had mine develop leaks there in the past. Also the heater hose that goes to the manifold, at the fitting. /forums/images/graemlins/thinking.gif
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Good ideas man, Ill check em out...
    Spring breaks comin up and we should get together and shoot the crap while Im home....
  7. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    I will PM you my # call me when you get home, leave a message if I am not there. /forums/images/graemlins/cool.gif
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Umm so yeah the leak is gone again... /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Its the water pump... /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    John
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Where are you John, these two weeks just aint been the same not talkin to you all day long. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif......Dont say waterpump...hopefully its the lowerhose.. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
