So one of the things about 57" springs...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Mar 3, 2003.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    So one of the things about 57\" springs...
    Is when you put them on the front, your approach angle will be screwed.
    See...I've been planning on doing 57's in the front and 63's in the rear. But the spring hangers probably will get in the way. So, any thoughts on running rear lift springs for a Ford (the 57's) and rear lift springs for a chebby tahoe (63's)?
    I'm wondering how the flex would be affected.
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: So one of the things about 57\" springs...
    What about grinding the rivets off the front hangers and moving them forward about 4 inches, then run a longer shackle in the rear to make up the difference. The eye will still be under the bumper.
    The stock centering pin is 23" from the front eye, the 57's are 25" from the front eye to the centering pin. You only need to make up 2 inches forward on the mount to put the axle back at its stock position. That would leave 32" from the centering pin back where a stock spring would only need 25" so you would need to make a shackle capable of spanning 7" and maintaining a small distance from the frame when completely flattened. It would probably need a 9" shackle and sit at a swept forward position. Definately an install deserving of limiting straps on each wheel!
    I like going with the 4" forward, move the front axle forward 2" and then only need a 7" shackle in the back... more along the lines of what the 57's are known to use when fully cycling.
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    You could also move the shackle assembly back a couple inches to get the shackle angle you want. Prolly wouldn't take more than an hour per side with the right tools.
    I'm slowly getting to the point where I feel there is a practical limit to flex before it becomes more problematic than it's worth. Issues like stability, body clearance, shock locations and steering issues all come into play.
    Even with stiff Rancho's up front and regular 57" rears I have yet to find a spot where I wished for or needed more flex than I have. Looking good on the ramp can really open up a pandora's box of other problems to deal with.
    rene
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You can say that again!
    I rather like having a stiff front end with a soft rear... or as Leiland would say... "We are still talking about trucks, right?"
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Also, the F150s are highly asymetric so the affect on the axle will be more dramatic when not at static height. For instance, if the passenger side droops, the spring bows into more and more of an inverted arch. The axle is in front of the center of the spring, so it will tend to rotate the pinion down more than a symetric spring.
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    So...I'm wondering if this is a good idea /forums/images/graemlins/grin.gif
    I'm thinking that I'd get pretty good flex...without spring hangers hanging down
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you kept the 57" springs stock it would be way too soft in the front.
    With that much flex you can't run a sway-bar and with springs that soft up front you would never want to drive it on the road.
    I think that a 57" spring is a bit on the long side for a front spring. I think a spring that was about 2" longer on the back half only would be the best way to go. ORD should be able to set you up with a nice spring.
    For the rear I would like to see someone run a stock 63" leaf but have a custom made 2nd leaf that was milatary wrapped. It shouldn't cost too much to get 2 leaves made...alot less than a custom pack.
    The other option for a rig that flexes well is inboarded rear springs.
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    If you go that route that'll be sweet! I just bought a set of 6" springs for the front and and gonna go with 57's in the rear. I decided I am not skilled enough to figure out how to do that set up.... you sure would get a lot of heads turning for sure. I have yet to see anyone out here do this. And you see a bit of everything up here with the Rubicon being so close and lots of things running around town....
  9. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I'm thinking that some rear lift springs off of a ford would be a little bit stiffer...possibly alleviating that problem
  10. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I'm trying to be different /forums/images/graemlins/grin.gif Prolly going to get myself in trouble /forums/images/graemlins/rotfl.gif
  11. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i just threw (yeah lol...like it was easy) the 63's under my k15, and i dont think there is a need for a military wrap, those leafes are VERY stiff. and a full 2nd leaf may stiffen it up more. the beef on the first leaf makes it look quite invinceable. but, i havent wheel it yet...hasnt left the garage yet...just finished it up
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    The only reason I'm planning on running 57's up front is because my front end is so light and I want a light spring rate. Basicly for my front sheetmetal, remove your whole front clip and place a trash can around the motor /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif thats a Willy's front,LMAO
    I'm planning on going with a combo of a longer shackle, lower front mount and moved forward.
    I was gonna run rear 52's but i figure if I'm gonna move em, I might as well just do the 57's and get it good and soft.
    -Jeremy
    "running 57's on a '55"
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you have the 3 leaf or the 4 leaf pack (not including the overload)?
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    -Jeremy
    I love those willy's wagons.
    I was going to use the 52" springs but then I decided like you if I am going to move the hanger go with longer but I chose the 56" stiffer spring, with a leave or 2 removed.
  15. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    3...2wd...overload is flipped
  16. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Damn!...and you still think they are too stiff!
    I have heard toyota guys say they were too soft with the 3 leaf.
    I guess I'll just have to bolt them up and find out.
  17. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i may be very, very wrong. i just slapped em on 3 days ago i finished, and the only tests have been chaining the truck down to the floor with a ratchet strap...
    i'll keep you updated
    RYan
